BSJ EH03T-V2
BSJ EH03T-V2 is a 4-channel AI dashcam built for commercial fleet management and driver safety. It records four 1080p video channels with H.264/H.265 encoding to dual TF card slots of up to 512GB each. A 2.0 TOPS NPU runs ADAS alerts for forward collision, headway, lane departure and pedestrian collision, plus DMS alerts for fatigue, phone use, smoking, distraction, seatbelt use and camera blocking. It connects over 4G LTE Cat.4 with 2G/3G fallback, supports GPS, Galileo, BeiDou and GLONASS positioning, and has 2.4GHz Wi-Fi. It runs on 9-36V DC vehicle power and has a 300mAh backup battery. The I/O includes ignition, an SOS input, turn-signal inputs and a fuel ADC input. A 3-axis G-sensor detects harsh driving and collisions. It supports live streaming, remote playback, Configurator setup and FOTA updates, and is CE, UKCA and NBTC certified.
Parameters (188)
Settings (18)
Commands (9)
BSJ EH03T-V2
Flespi parses telemetry data from your BSJ EH03T-V2 into a standardized JSON and lets you send commands to BSJ EH03T-V2 via API.
    "device.type.id": "BSJ EH03T-V2",
    "protocol.id": "bsj"
How to send commands to BSJ EH03T-V2?
accelerometer.module.status
Additional info ID 0x67
adas.blindspot.side
Additional info ID 0x2B,
Additional info ID 0x65,
Additional info ID 0x66,
Additional info ID 0x67,
Additional info ID 0x70,
Additional info ID 0xA1,
Message ID 0x1212
brake.status
Brake status
driver.card.reading.error
Driver card reading error
Message ID 0x0702
Message ID 0x0702
Message ID 0x0702
driver.registration.status
Driver registration status
Message ID 0x0702
driving.alarm.bitmask
Additional info ID 0x18
dsm.device.occlusion.event
Additional info ID 0x18,
dsm.fatigue.degree
Additional info ID 0x04,
Message ID 0x0301,
gps.signal.level
GPS signal level
high.temperature.alarm
High temperature alarm
low.temperature.alarm
Low temperature alarm
media.filename
Multimedia file name
Message ID 0x1211,
Message ID 0x1212
media.filesize
Multimedia file size
Message ID 0x1211,
Message ID 0x1212
Message ID 0x1211,
Message ID 0x1212
memory.fault.status.bitmask
Additional info ID 0x17
Message ID 0x0F00...0x0FFF
position.source
Additional info ID 0x2A,
storage.media.free.size
megabytes
storage.media.malfunction
storage.media.total.size
megabytes
storage.media.type
Storage media type, indexed
storage.media.valid
Message ID 0x0702,
Message ID 0x1212
tire.error.status
Tire status error
tire.leak.status
Tire leak detected
tire.overpressure.status
Tire overpressure
tire.underpressure.status
Tire underpressure
upgrade.status.name
Upgrade status
Message ID 0x0108
upgrade.type
Upgrade type
Message ID 0x0108
video.alarm.bitmask
Video alarm flags bitmask
Additional info ID 0x14
Additional info ID 0x16
Additional info ID 0x15
Special alarm recording
alarm_recording
duration: Maximum duration
username: Username
Default report interval
default_interval
Dormancy report interval
dormancy_interval
Terminal factory reset
factory_reset
Heartbeat interval
heartbeat
Highest speed
highest_speed
Video & Audio attributes
media_attributes
audio_codec: Audio codec
video_codec: Video codec
Vehicle odometer
mileage: Mileage
Overspeed duration
overspeed_duration
Report strategy
report_strategy
Terminal reset
Server
address: Server address
tcp_port: TCP port
Sleep and wake-up mode
sleep_wakeup
timed_wakeup: Timed wake-up
manual_wakeup: Manual wake-up
stream_parameters
bitrate: Bitrate
frame_rate: Frame rate
resolution: Resolution
audio_output: Audio output
encoding_mode: Encoding mode
Blocked video alarms
video_alarm_blocked
bus_overload: Bus overload
Video analysis alarm
video_analysis_alarm
Check terminal parameter
{"message_id":"8104"}
alarm_id: Alarm ID
Send message to driver
notify_driver
text: Message
type: Message type
speak: Read aloud
urgent: Urgent
display: Show on the screen
encoding: Text encoding
storage_type: Storage type
Start audiostream
start_audiostream
Start audio stream session
type: Audio mode
quality: Quality
