BSJ ED08R-V2
BSJ ED08R-V2 is an enterprise-grade 8-channel AI-powered MDVR for large commercial fleets in logistics, construction and public transport. It records up to eight 1080p or 720p channels in H.264/H.265 to SD card and hard disk, and uploads video in real time. A 2.0 TOPS NPU runs ADAS, DMS and blind spot detection algorithms. Connectivity includes 4G LTE Cat.4 with 2G/3G fallback, 2.4GHz Wi-Fi and GPS, Galileo, BeiDou and GLONASS positioning. It runs on 9-36V DC vehicle power and has a 3-axis G-sensor for driving behavior alerts. Interfaces include SOS, ACC, turn signal, brake and door inputs, plus 1-Wire, RS485 and RS232, with remote setup and firmware updates through the BSJ Configurator and FOTA Web.
Parameters (188)
Settings (18)
Commands (9)
BSJ ED08R-V2
Flespi parses telemetry data from your BSJ ED08R-V2 into a standardized JSON and lets you send commands to BSJ ED08R-V2 via API.
    "device.type.id": "BSJ ED08R-V2",
    "protocol.id": "bsj"
How to send commands to BSJ ED08R-V2?
accelerometer.module.status
Additional info ID 0x67
adas.blindspot.side
Additional info ID 0x2B,
Additional info ID 0x65,
Additional info ID 0x66,
Additional info ID 0x67,
Additional info ID 0x70,
Additional info ID 0xA1,
Message ID 0x1212
brake.status
Brake status
driver.card.reading.error
Driver card reading error
Message ID 0x0702
Message ID 0x0702
Message ID 0x0702
driver.registration.status
Driver registration status
Message ID 0x0702
driving.alarm.bitmask
Additional info ID 0x18
dsm.device.occlusion.event
Additional info ID 0x18,
dsm.fatigue.degree
Additional info ID 0x04,
Message ID 0x0301,
gps.signal.level
GPS signal level
high.temperature.alarm
High temperature alarm
low.temperature.alarm
Low temperature alarm
media.filename
Multimedia file name
Message ID 0x1211,
Message ID 0x1212
media.filesize
Multimedia file size
Message ID 0x1211,
Message ID 0x1212
Message ID 0x1211,
Message ID 0x1212
memory.fault.status.bitmask
Additional info ID 0x17
Message ID 0x0F00...0x0FFF
position.source
Additional info ID 0x2A,
storage.media.free.size
megabytes
storage.media.malfunction
storage.media.total.size
megabytes
storage.media.type
Storage media type, indexed
storage.media.valid
Message ID 0x0702,
Message ID 0x1212
tire.error.status
Tire status error
tire.leak.status
Tire leak detected
tire.overpressure.status
Tire overpressure
tire.underpressure.status
Tire underpressure
upgrade.status.name
Upgrade status
Message ID 0x0108
upgrade.type
Upgrade type
Message ID 0x0108
video.alarm.bitmask
Video alarm flags bitmask
Additional info ID 0x14
Additional info ID 0x16
Additional info ID 0x15
Special alarm recording
alarm_recording
duration: Maximum duration
username: Username
Default report interval
default_interval
Dormancy report interval
dormancy_interval
Terminal factory reset
factory_reset
Heartbeat interval
heartbeat
Highest speed
highest_speed
Video & Audio attributes
media_attributes
audio_codec: Audio codec
video_codec: Video codec
Vehicle odometer
mileage: Mileage
Overspeed duration
overspeed_duration
Report strategy
report_strategy
Terminal reset
Server
address: Server address
tcp_port: TCP port
Sleep and wake-up mode
sleep_wakeup
timed_wakeup: Timed wake-up
manual_wakeup: Manual wake-up
stream_parameters
bitrate: Bitrate
frame_rate: Frame rate
resolution: Resolution
audio_output: Audio output
encoding_mode: Encoding mode
Blocked video alarms
video_alarm_blocked
bus_overload: Bus overload
Video analysis alarm
video_analysis_alarm
Check terminal parameter
{"message_id":"8104"}
alarm_id: Alarm ID
Send message to driver
notify_driver
text: Message
type: Message type
speak: Read aloud
urgent: Urgent
display: Show on the screen
encoding: Text encoding
storage_type: Storage type
Start audiostream
start_audiostream
Start audio stream session
type: Audio mode
quality: Quality
