BSJ EG01G
BSJ EG01G is a 4G Cat.1 rechargeable wireless GPS tracker for asset protection and fleet use. It has a 7500 mAh lithium battery with Type-C charging and a strong magnetic mount for hidden installation. Positioning uses GPS, Galileo, BeiDou and GLONASS with accuracy under 2.0 m CEP. Its IP67-rated housing measures 95 x 72 x 35 mm. Three working modes trade update rate for battery life: tracking mode lasts about 10 days, smart power saving about 90 days, and deep power saving up to about 3 years. Alerts include SOS, light-sensor tamper detection, low voltage, speeding, harsh braking, harsh acceleration, harsh turning and collision. The device is set up through a configurator tool, FOTA web, SMS or a monitoring platform. It is certified to CE, FCC, E-Mark and UKCA.
Parameters (188)
Settings (11)
BSJ EG01G
Flespi parses telemetry data from your BSJ EG01G into a standardized JSON and lets you send commands to BSJ EG01G via API.
    "device.type.id": "BSJ EG01G",
    "protocol.id": "bsj"
How to send commands to BSJ EG01G?
accelerometer.module.status
Additional info ID 0x67
adas.blindspot.side
Additional info ID 0x2B,
Additional info ID 0x65,
Additional info ID 0x66,
Additional info ID 0x67,
Additional info ID 0x70,
Additional info ID 0xA1,
Message ID 0x1212
brake.status
Brake status
driver.card.reading.error
Driver card reading error
Message ID 0x0702
Message ID 0x0702
Message ID 0x0702
driver.registration.status
Driver registration status
Message ID 0x0702
driving.alarm.bitmask
Additional info ID 0x18
dsm.device.occlusion.event
Additional info ID 0x18,
dsm.fatigue.degree
Additional info ID 0x04,
Message ID 0x0301,
gps.signal.level
GPS signal level
high.temperature.alarm
High temperature alarm
low.temperature.alarm
Low temperature alarm
media.filename
Multimedia file name
Message ID 0x1211,
Message ID 0x1212
media.filesize
Multimedia file size
Message ID 0x1211,
Message ID 0x1212
Message ID 0x1211,
Message ID 0x1212
memory.fault.status.bitmask
Additional info ID 0x17
Message ID 0x0F00...0x0FFF
position.source
Additional info ID 0x2A,
storage.media.free.size
megabytes
storage.media.malfunction
storage.media.total.size
megabytes
storage.media.type
Storage media type, indexed
storage.media.valid
Message ID 0x0702,
Message ID 0x1212
tire.error.status
Tire status error
tire.leak.status
Tire leak detected
tire.overpressure.status
Tire overpressure
tire.underpressure.status
Tire underpressure
upgrade.status.name
Upgrade status
Message ID 0x0108
upgrade.type
Upgrade type
Message ID 0x0108
video.alarm.bitmask
Video alarm flags bitmask
Additional info ID 0x14
Additional info ID 0x16
Additional info ID 0x15
username: Username
Default report interval
default_interval
Dormancy report interval
dormancy_interval
Terminal factory reset
factory_reset
Heartbeat interval
heartbeat
Highest speed
highest_speed
Vehicle odometer
mileage: Mileage
Overspeed duration
overspeed_duration
Report strategy
report_strategy
Terminal reset
Server
address: Server address
tcp_port: TCP port
Check terminal parameter
{"message_id":"8104"}
