Jimi IoT (Concox) AT4U
Concox AT4U is a rugged asset GPS tracking unit with a 10,000mAh battery, a powerful magnetic mount, and a built-in MIC for voice monitoring. It operates over 3G (850/900/1900/2100MHz WCDMA and 850/900/1800/1900MHz GSM). The device features an intelligent power management system, a tamper alert, and more. The casing complies with IPx5 rating making it resistant to water spray.
Parameters (494)
Settings (5)
Flespi parses telemetry data from your Jimi IoT (Concox) AT4U into a standardized JSON and lets you send commands to Jimi IoT (Concox) AT4U via API.
    "device.type.id": "Jimi IoT (Concox) AT4U",
How to send commands to Jimi IoT (Concox) AT4U?
KD031 CAN data ID 0x0537,
KD031 CAN data ID 0x0526,
KD031 CAN data ID 0x0530,
KD031 CAN data ID 0x053B,
KD031 CAN data ID 0x010F,
KD031 CAN data ID 0xFEE9,
KD031 CAN data ID 0x0552,
KD031 CAN data ID 0x0111,
KD031 CAN data ID 0xEEF6,
KD031 CAN data ID 0x053D,
KD031 CAN data ID 0xF00A,
KD031 CAN data ID 0x0547,
Protocol Number 0x15
Configure APN parameters
Restart Device
Server Setup
comm: Communication Mode
mode: Host Mode
SOS Numbers
sos_numbers
SOS Phone Numbers Setup
delete: Delete Numbers
phone1: First Number
phone2: Second Number
phone3: Third Number
Vibration Alarm
vibr_alarm
Vibration Alarm Setup
vibr: Enable Alarm
