Jimi IoT (Concox) AT5
Concox AT5 is a solar-powered GPS tracker primarily designed for cargo and ships. The device features GPS+LBS positioning, tamper alert, 10000mAh battery, IPX7 waterproof casing, and more.
Parameters (353)
Flespi parses telemetry data from your Jimi IoT (Concox) AT5 into a standardized JSON and lets you send commands to Jimi IoT (Concox) AT5 via API.
    "device.type.id": "Jimi IoT (Concox) AT5",
How to send commands to Jimi IoT (Concox) AT5?
abnormal.tier.pressure.alarm
can.brake.pedal.status
Protocol Number 0x39
Protocol Number 0x15
Configure APN parameters
Server Setup
comm: Communication Mode
mode: Host Mode
