Jimi IoT (Concox) AT6
Concox AT6 is a modern 3G asset GPS tracker. The device works over 850/900/1900/2100MHz WCDMA and 850/900/1800/1900MHz GSM. The device features a 10000 mAh Li-Ion battery (with the life up to 2 years), magnetic and waterproof IPX5 casing, intelligent power management, a tamper alert, etc.
Parameters (494)
Settings (19)
Flespi parses telemetry data from your Jimi IoT (Concox) AT6 into a standardized JSON and lets you send commands to Jimi IoT (Concox) AT6 via API.
    "device.type.id": "Jimi IoT (Concox) AT6",
How to send commands to Jimi IoT (Concox) AT6?
KD031 CAN data ID 0x0537,
KD031 CAN data ID 0x0526,
KD031 CAN data ID 0x0530,
KD031 CAN data ID 0x053B,
KD031 CAN data ID 0x010F,
KD031 CAN data ID 0xFEE9,
KD031 CAN data ID 0x0552,
KD031 CAN data ID 0x0111,
KD031 CAN data ID 0xEEF6,
KD031 CAN data ID 0x053D,
KD031 CAN data ID 0xF00A,
KD031 CAN data ID 0x0547,
Protocol Number 0x39
Protocol Number 0x15
Angle Report
angle_report
Angle Change Report Setup
angle_rep: Enable Angle Report
Automatic APN
auto_apn
Automatic APN detection
enable: Enable Automatic APN
Battery Alarm
bat_alarm2
Battery Alarm Setup
battery: Enable Alarm
GPS Blind Alarm
blind_alarm2
GSP Blind Area Alarm Setup
blind: Enable Alarm
Boot Alarm
boot_alarm
Device Power On Alarm
boot: Enable Alarm
Cover Remove Alarm
cover_alarm
Device Cover Remove Alarm
cover: Enable Alarm
Heartbeat Interval
hbt_ival
time_ival: Heartbeat Interval
Configure APN parameters
Restart Device
Server Setup
comm: Communication Mode
mode: Host Mode
Shutdown Alarm
shutdown_alarm
Device Power Off Alarm
shutdown: Enable Alarm
SOS Numbers To Receive Alarms
sos_alarm_numbers
Set SOS numbers to receivcve alarms, except SOS alarm
first: First SOS Number
third: Third SOS Number
second: Second SOS Number
SOS Numbers
sos_numbers
SOS Phone Numbers Setup
delete: Delete Numbers
phone1: First Number
phone2: Second Number
phone3: Third Number
Static Mode
stop_mode
Static mode settings when to shutdown the GPS, GRPS and GSM.
time_gps: GPS Off Time Interval
time_gsm: GSM Off Time Interval
time_gprs: GPRS Off Time Interval
time_wakeup: Wake Up Time Interval
Tamper Alarm
tamper_alarm
Tamper Alarm Setup
tamper: Enable Alarm
Exit Tamper Alarm
tamper_cancel
Tamper Alarm Track Time
track_time
Set the track time after tamper alarm triggeres in ultra-long standby mode
time: Track Time
Vibration Alarm
vibr_alarm
Vibration Alarm Setup
vibr: Enable Alarm
Working Mode
working_mode
Device working mode settings
mode: Working Mode
