Jimi IoT (Concox) BL11
Concox BL11 is a Cat M1/NB2 GPS bike-sharing lock. The device features GPS/WIFI/LBS/Beacon positioning, a large 10,000 mAh battery, solar battery, IP66 dust- and water-resistant casing, vibration alert, TLS data encryption, and more.
Parameters (356)
Settings (20)
Flespi parses telemetry data from your Jimi IoT (Concox) BL11 into a standardized JSON and lets you send commands to Jimi IoT (Concox) BL11 via API.
    "device.type.id": "Jimi IoT (Concox) BL11",
How to send commands to Jimi IoT (Concox) BL11?
can.brake.pedal.status
Protocol Number 0x39
Protocol Number 0x15
Automatic APN
auto_apn
Automatic APN detection
enable: Enable Automatic APN
Check
check
Obtain general information about the device. The response will be stored as a message
Clear all location data
clear
Backup GPS data will clear
Factory reset
factory
Restore to factory settings (except domain name/APN/locked domain name)
Find
find_device
Find a device by sound
ival: Timeout
ring: Ring Interval
count: Rings Count
Query device network setting
gprsset
The swith of GPS location
gps
GPS location upload switch
G-Sensor sensitivity
g_sens_level
G-Sensor sensitivity level
level: Level
Heartbeat
hrbt_ival
Heartbeat interval
ival: Interval
Low Battery Alarm
low_bat_alarm
Low battery alarm settings
Configure APN parameters
Open the lock
open
Device will unlock and response the currently state
Transport Mode
pwrsave
Enter into transport mode
Restart Device
Reset Motor
rstmotor
Reset
Server Setup
server4
mode: Host Mode
Status
status
Update status of the device
GPS data sending interval
timer4
time: GPS upload interval
timezone
Time Zone Setup
Vibration Alarm
vibr_alarm2
Vibration alarm
