Gosafe G1C
The G1C is a compact GPS tracker for vehicles and motorcycles, featuring LTE CAT 1 connectivity, internal GPS and cellular antennas, ignition detection, crash data recording, 3D accelerometer, geo-fence management, and water-resistant IP65 design. It supports GPS+GLONASS, has a backup battery, digital input for panic button, and is easy to install with multiple mounting options. Ideal for UBI, stolen vehicle recovery, fleet management, and insurance applications.
Parameters (158)
Gosafe G1C
Flespi parses telemetry data from your Gosafe G1C into a standardized JSON and lets you send commands to Gosafe G1C via API.
    "device.type.id": "Gosafe G1C",
    "protocol.id": "gosafe"
How to send commands to Gosafe G1C?
accident.event
Accident event detected
Alarm mark bitmask
backup.battery.voltage.status
Alarm mark bitmask
call.status
Call status bit
cornering.acceleration
Cornering acceleration
crash.timestamp
Crash timestamp
device.mode
Device working mode code
Additional info ID 0x2A,
Alarm mark bitmask
flash.storage.status
Flash storage status
frequency.counter.din
fuel.weight
Fuel weight
Alarm mark bitmask
gsm.sim.balance
SIM card balance
hardware.fault.code
Hardware fault code
hardware.malfunction.alert
Alarm mark bitmask
Alarm mark bitmask
harsh.turn.event
Harsh turn event detected
Alarm mark bitmask
Alarm mark bitmask
message.content
Message content
Alarm mark bitmask
position.fix.type
Alarm mark bitmask
Alarm mark bitmask
Alarm mark bitmask
Alarm mark bitmask
Alarm mark bitmask
sensor.status
socket.connection.status
Socket connection status
Alarm mark bitmask
trip.type
Trip type (Private, Business)
turnover.event
Turnover event
Alarm mark bitmask
Alarm mark bitmask
