Gosafe G1C Easy install
The G1C Easy Install is a compact, economical vehicle GPS tracker with LTE, IP65 water resistance, and direct battery connection. It features a 3D accelerometer for trip detection and driving behavior analysis, 50-channel GPS+GLONASS, AGPS, geo-fence management, and low power consumption. Ideal for insurance telematics, rental, leasing, and fleet management, it supports 12V/24V systems, has internal GSM/GPS antennas, backup battery, and robust environmental tolerance.
Parameters (158)
Flespi parses telemetry data from your Gosafe G1C Easy install into a standardized JSON and lets you send commands to Gosafe G1C Easy install via API.
    "device.type.id": "Gosafe G1C Easy install",
    "protocol.id": "gosafe"
How to send commands to Gosafe G1C Easy install?
accident.event
Accident event detected
Alarm mark bitmask
backup.battery.voltage.status
Alarm mark bitmask
call.status
Call status bit
cornering.acceleration
Cornering acceleration
crash.timestamp
Crash timestamp
device.mode
Device working mode code
Additional info ID 0x2A,
Alarm mark bitmask
flash.storage.status
Flash storage status
frequency.counter.din
fuel.weight
Fuel weight
Alarm mark bitmask
gsm.sim.balance
SIM card balance
hardware.fault.code
Hardware fault code
hardware.malfunction.alert
Alarm mark bitmask
Alarm mark bitmask
harsh.turn.event
Harsh turn event detected
Alarm mark bitmask
Alarm mark bitmask
message.content
Message content
Alarm mark bitmask
position.fix.type
Alarm mark bitmask
Alarm mark bitmask
Alarm mark bitmask
Alarm mark bitmask
Alarm mark bitmask
sensor.status
socket.connection.status
Socket connection status
Alarm mark bitmask
trip.type
Trip type (Private, Business)
turnover.event
Turnover event
Alarm mark bitmask
Alarm mark bitmask
