Gosafe G1C-Mini
G1C Mini is a compact GPS tracker designed for motorcycles and fleet vehicles, featuring IP65 water resistance, 3-axis accelerometer, ignition input, starter block, internal GSM and GPS antennas, and support for GPS+GLONASS. It offers GPRS/SMS communication, geo-fence management, low power consumption, and a backup battery, making it ideal for versatile vehicle tracking applications.
Parameters (158)
Gosafe G1C-Mini
Flespi parses telemetry data from your Gosafe G1C-Mini into a standardized JSON and lets you send commands to Gosafe G1C-Mini via API.
    "device.type.id": "Gosafe G1C-Mini",
    "protocol.id": "gosafe"
How to send commands to Gosafe G1C-Mini?
accident.event
Accident event detected
Alarm mark bitmask
backup.battery.voltage.status
Alarm mark bitmask
call.status
Call status bit
cornering.acceleration
Cornering acceleration
crash.timestamp
Crash timestamp
device.mode
Device working mode code
Additional info ID 0x2A,
Alarm mark bitmask
flash.storage.status
Flash storage status
frequency.counter.din
fuel.weight
Fuel weight
Alarm mark bitmask
gsm.sim.balance
SIM card balance
hardware.fault.code
Hardware fault code
hardware.malfunction.alert
Alarm mark bitmask
Alarm mark bitmask
harsh.turn.event
Harsh turn event detected
Alarm mark bitmask
Alarm mark bitmask
message.content
Message content
Alarm mark bitmask
position.fix.type
Alarm mark bitmask
Alarm mark bitmask
Alarm mark bitmask
Alarm mark bitmask
Alarm mark bitmask
sensor.status
socket.connection.status
Socket connection status
Alarm mark bitmask
Message ID 0x0704
trip.type
Trip type (Private, Business)
turnover.event
Turnover event
Alarm mark bitmask
Alarm mark bitmask
