Gosafe G2C
The G2C is a rugged asset tracker with up to 10 years battery life, powered by 6 replaceable CR123 batteries. It features GPS, Beidou, Wi-Fi, and LBS location technologies, LTE CAT-1 connectivity, IPX7 waterproof rating, intelligent power management, FOTA, deep sleep mode, and flexible reporting modes. The device supports both periodic and movement-based tracking, has an internal antenna, and operates in extreme temperatures, making it ideal for long-term asset monitoring in harsh environments.
Parameters (158)
Gosafe G2C
Flespi parses telemetry data from your Gosafe G2C into a standardized JSON and lets you send commands to Gosafe G2C via API.
    "device.type.id": "Gosafe G2C",
    "protocol.id": "gosafe"
How to send commands to Gosafe G2C?
accident.event
Accident event detected
Alarm mark bitmask
backup.battery.voltage.status
Alarm mark bitmask
call.status
Call status bit
cornering.acceleration
Cornering acceleration
crash.timestamp
Crash timestamp
device.mode
Device working mode code
Additional info ID 0x2A,
Alarm mark bitmask
flash.storage.status
Flash storage status
frequency.counter.din
fuel.weight
Fuel weight
Alarm mark bitmask
gsm.sim.balance
SIM card balance
hardware.fault.code
Hardware fault code
hardware.malfunction.alert
Alarm mark bitmask
Alarm mark bitmask
harsh.turn.event
Harsh turn event detected
Alarm mark bitmask
Alarm mark bitmask
message.content
Message content
Alarm mark bitmask
position.fix.type
Alarm mark bitmask
Alarm mark bitmask
Alarm mark bitmask
Alarm mark bitmask
Alarm mark bitmask
sensor.status
socket.connection.status
Socket connection status
Alarm mark bitmask
Message ID 0x0704
trip.type
Trip type (Private, Business)
turnover.event
Turnover event
Alarm mark bitmask
Alarm mark bitmask
