iStartek VT100
iStartek VT100 is an IP66 waterproof GPS tracker. The device features 9-100V operating range, SOS alarm, remote cut-off (petrol/power), Driver Behavior Monitoring, impact / idle / tow / fatigue driving alarm, GPS +BD2 tracking, low fuel and fuel theft alarm, multiple I/O, 55 mAh Li-Ion Battery.
Parameters (192)
Settings (5)
iStartek VT100
Flespi parses telemetry data from your iStartek VT100 into a standardized JSON and lets you send commands to iStartek VT100 via API.
    "device.type.id": "iStartek VT100",
    "protocol.id": "istartek"
How to send commands to iStartek VT100?
arm.status
can.adas.status
can.alternator.status
can.asr.status
can.awd.status
can.doors.state
Doors state read from CAN
can.fuel.rate
Fuel rate read from CAN
Message ID 0x0704
can.retarder.selection
can.retarder.torque.mode
Message ID 0x0704
citizen.card.province
Card province
citizen.card.type
Citizen card type
city.id
ID of device's home city"
Message ID 0x0704
driver.gender
Driver gender
fuel.flow.meter.fuel.consumed
fuel.steal.alarm
Fuel steal alarm
fuel.tank.enum
Fuel tank index
lbs.alarm
LBS alarm
low.speed.alarm
manufacturer.code
Device manufacturer code"
manufacturer.device.code
Message ID 0x0704
overtime.driving.alarm
Overtime driving alarm
picture.event
Picture event
picture.name
Picutre name
Message ID 0x0704
Message ID 0x0704
Message ID 0x0704
province.id
ID of device's home province"
server1.connection.status
Server 1 connection status
server2.connection.status
Server 2 connection status
stealing.alarm
Stealing alarm
stealing.trigger
Stealing trigger
tacho.driving.direction
tacho.handling.info.status
tacho.performance
Tachograph performance
tacho.system.event.status
Tacho system event occurred
trip.max.rpm
wakeup.trigger
Wake up trigger
Set APN
Set up a Backup Server for Server 1
backup_server1
Set the GPRS parameters of Server 1
main_server1
mode: GPRS connection mode
Set the GPRS parameters of Server 2
main_server2
Set sms password
sms_cmd_password
Set SMS Command Password
password: SMS password
Enable output 1 for device VT200-L
{"text":"900,1,1"}
