iStartek VT202
iStartek VT202 is a compact GPS tracker for motorcycles, electric bicycles, or car monitoring. The device features a 120mAh backup battery, various anti-theft alarms, engine cut (engine immobilization), ACC detection, and more.
Parameters (192)
Settings (12)
iStartek VT202
Flespi parses telemetry data from your iStartek VT202 into a standardized JSON and lets you send commands to iStartek VT202 via API.
    "device.type.id": "iStartek VT202",
    "protocol.id": "istartek"
How to send commands to iStartek VT202?
arm.status
can.adas.status
can.alternator.status
can.asr.status
can.awd.status
can.doors.state
Doors state read from CAN
can.fuel.rate
Fuel rate read from CAN
Message ID 0x0704
can.retarder.selection
can.retarder.torque.mode
Message ID 0x0704
citizen.card.province
Card province
citizen.card.type
Citizen card type
city.id
ID of device's home city"
Message ID 0x0704
driver.gender
Driver gender
fuel.flow.meter.fuel.consumed
fuel.steal.alarm
Fuel steal alarm
fuel.tank.enum
Fuel tank index
lbs.alarm
LBS alarm
low.speed.alarm
manufacturer.code
Device manufacturer code"
manufacturer.device.code
Message ID 0x0704
overtime.driving.alarm
Overtime driving alarm
picture.event
Picture event
picture.name
Picutre name
Message ID 0x0704
Message ID 0x0704
Message ID 0x0704
province.id
ID of device's home province"
server1.connection.status
Server 1 connection status
server2.connection.status
Server 2 connection status
stealing.alarm
Stealing alarm
stealing.trigger
Stealing trigger
tacho.driving.direction
tacho.handling.info.status
tacho.performance
Tachograph performance
tacho.system.event.status
Tacho system event occurred
trip.max.rpm
wakeup.trigger
Wake up trigger
Set ACC alarm switch (DP36)
acc_alarm
status: Switch status
Set bound domain name or IP and port (DP20)
bound_server
mode: Host Mode
Deep sleep and recovery voltage
deep_sleep_voltage
Set deep sleep trigger voltage and recovery voltage (DP22)
recovery_voltage: Recovery voltage
deep_sleep_trigger_voltage: Deep sleep trigger voltage
Dormant switch
dormant_switch
Set dormant state switch at rest (DP21)
switch_status: Switch status
External low voltage
external_voltage
Set external low voltage alarm (DP23)
voltage: Voltage
Heartbeat interval
heartbeat_interval
Time interval between equipment reporting heartbeat packet (DP25)
interval: Heartbeat interval
Oil circuit control
oil_control
Cut-off (BP03) and restore (BP04) oil circuit
Immediate positioning (DP35)
positioning
Power circuit control
power_control
Cut-off (BP03) and restore (BP04) power circuit
Remote restart (BP61)
restart
Set standby IP and port (DP19)
standby_server
mode: Host Mode
Upload interval
upload_interval
Set upload time interval (BP07)
interval: Upload interval
Enable output 1 for device VT200-L
{"text":"900,1,1"}
