Maxtrack MXT-150
Maxtrack MXT-150 is a vehicle GPS tracker with two installation options: with external or internal GPS antenna. The device features quadband communication support, internal backup battery, sleep mode, 4 digital inputs, one pre-defined input for ignition, and more.
Parameters (105)
Settings (19)
Maxtrack MXT-150
Flespi parses telemetry data from your Maxtrack MXT-150 into a standardized JSON and lets you send commands to Maxtrack MXT-150 via API.
    "device.type.id": "Maxtrack MXT-150",
    "protocol.id": "maxtrack"
How to send commands to Maxtrack MXT-150?
air.pressure
Air pressure
Message Type 0x0001
Message Type 0x0001,
Message Type 0x31
Message Type 0x0001
Message Type 0x31
Message Type 0x31
Message Type 0x31
Message Type 0x0001
Message Type 0x0001
battery.use.duration
Message Type 0x31
Message Type 0x31
Message Type 0x0001
Message Type 0x0001
Message Type 0x0001
Message Type 0x0001
Message Type 0x0001
Message Type 0x0001
Message Type 0x0001
Message Type 0x0001
Message Type 0x0001
Message Type 0x0001
Message Type 0x0001
Message Type 0x2A
device.lifetime
Message Type 0x0001
Message Type 0x31
Message Type 0x0001
Message Type 0x31
Message Type 0x31
Message Type 0x31
Message Type 0x0001
Message Type 0x31
Message Type 0x31
Message Type 0x0001
Message Type 0x0001
event.duration
Telemetry event duration
Message Type 0x0001
Message Type 0x31
Message Type 0x31
Message Type 0x0001
Message Type 0x31
Message Type 0x0001
Message Type 0x31
gnss.type
Message Type 0x0001
Message Type 0x31
Message Type 0x0001
Message Type 0x31
Message Type 0x31
Message Type 0x31
Message Type 0x31
Message Type 0x31
Message Type 0x0001
Message Type 0x0001
Message Type 0x31
Message Type 0x0001
Message Type 0x0001
Message Type 0x0002,
Message Type 0x0003,
Message Type 0x0011
Message Type 0x0001
Message Type 0x0001
Message Type 0x0011
Message Type 0x0011
ignition.calibration.max.used
Message Type 0x0011
Message Type 0x0011
ignition.calibration.min.used
Message Type 0x0011
Message Type 0x0011
ignition.calibration.voltage
Message Type 0x0011
Message Type 0x0001
last.reboot.id
Message Type 0x0001
lora.fcntup
Message Type 0x0001
Message Type 0x31
Message Type 0x2A
Message Type 0x31
Message Type 0x31
Message Type 0x0001
Message Type 0x31
Message Type 0x0001
Message Type 0x31
Message Type 0x31
Message Type 0x31
Message Type 0x31
Message Type 0x0001
Message Type 0x31
Message Type 0x31
power.state.enum
Power state
Message Type 0x0001
product.model.enum
Product model
Message Type 0x0011
Message Type 0x0011
Message Type 0x0001
Message Type 0x31
Message Type 0x31
Message Type 0x0011,
Message Type 0x31
total.idle.time
Message Type 0x31
Message Type 0x0001
vehicle.battery.state
Battery state of the vehicle
Message Type 0x0001
Message Type 0x0001
Message Type 0x0001
wifi.status
Wifi connection status
Message Type 0x0001
zigbee.hardware.version
ZigBee hardware version
Message Type 0x2A
zigbee.status
Zigbee connection status
Message Type 0x0001
Accessories Broadcast List
accessories_broadcast_list
list: List
Accessories Link List
accessories_link_list
list: List
Accessories Sync List
accessories_sync_list
list: List
Accessories Tag List
accessories_tag_list
list: List
Anti-theft function
antitheft
backend_server2
Calibrate ignition voltage
calibrate_ignition
Set up hourmeter counter
hourmeter
counter: Counter
Set the voltage threshold ignition measure
ignition
Enable Digital Inputs
inputs
input1: Enable input 1
input2: Enable input 2
input3: Enable input 3
input4: Enable input 4
mode: Connection type
Set up odometer counter
counter: Counter
Enable Digital Output 1
enable: Enable or Disable output 1
Enable Digital Output 2
enable: Enable or Disable output 2
Enable Digital Output 3
output3
enable: Enable or Disable output 3
Activate or deactivate panic
panic
enable: Enable Panic mode
Restart the Device
Report Interval
report_interval
Setup Report intervals.
enable_wap: Enable WAP
enable_reason: Enable Reason
enable_voltage: Enable detail information of the voltage
resend_timeout: Resend Timeout
timeout_moving: Timeout moving
timer_of_panic: Panic status reporting interval
enable_gps_info: Enable GPS info
enable_odometer: Enable odometer
resend_attempts: Resend Attempts
enable_driver_id: Enable Driver ID
timer_of_movement: device moving reporting interval
enable_waypoint_id: Enable Waypoint ID
keep_working_timer: keep working timer after ignition off
enable_engine_hours: Enable engine hours
timer_of_ignition_off: Ignition OFF reporting interval
Custom binary command
custom_binary
Custom protobuf command
custom_protobuf
