Maxtrack MXT-160
Maxtrack MXT-160 is a vehicle GPS tracker with IP67 protective casing.
Parameters (105)
Settings (19)
Maxtrack MXT-160
Flespi parses telemetry data from your Maxtrack MXT-160 into a standardized JSON and lets you send commands to Maxtrack MXT-160 via API.
    "device.type.id": "Maxtrack MXT-160",
    "protocol.id": "maxtrack"
How to send commands to Maxtrack MXT-160?
air.pressure
Air pressure
Message Type 0x0001
Message Type 0x0001,
Message Type 0x31
Message Type 0x0001
Message Type 0x31
Message Type 0x31
Message Type 0x31
Message Type 0x0001
Message Type 0x0001
battery.use.duration
Message Type 0x31
Message Type 0x31
Message Type 0x0001
Message Type 0x0001
Message Type 0x0001
Message Type 0x0001
Message Type 0x0001
Message Type 0x0001
Message Type 0x0001
Message Type 0x0001
Message Type 0x0001
Message Type 0x0001
Message Type 0x0001
Message Type 0x2A
device.lifetime
Message Type 0x0001
Message Type 0x31
Message Type 0x0001
Message Type 0x31
Message Type 0x31
Message Type 0x31
Message Type 0x0001
Message Type 0x31
Message Type 0x31
Message Type 0x0001
Message Type 0x0001
event.duration
Telemetry event duration
Message Type 0x0001
Message Type 0x31
Message Type 0x31
Message Type 0x0001
Message Type 0x31
Message Type 0x0001
Message Type 0x31
gnss.type
Message Type 0x0001
Message Type 0x31
Message Type 0x0001
Message Type 0x31
Message Type 0x31
Message Type 0x31
Message Type 0x31
Message Type 0x31
Message Type 0x0001
Message Type 0x0001
Message Type 0x31
Message Type 0x0001
Message Type 0x0001
Message Type 0x0002,
Message Type 0x0003,
Message Type 0x0011
Message Type 0x0001
Message Type 0x0001
Message Type 0x0011
Message Type 0x0011
ignition.calibration.max.used
Message Type 0x0011
Message Type 0x0011
ignition.calibration.min.used
Message Type 0x0011
Message Type 0x0011
ignition.calibration.voltage
Message Type 0x0011
Message Type 0x0001
last.reboot.id
Message Type 0x0001
lora.fcntup
Message Type 0x0001
Message Type 0x31
Message Type 0x2A
Message Type 0x31
Message Type 0x31
Message Type 0x0001
Message Type 0x31
Message Type 0x0001
Message Type 0x31
Message Type 0x31
Message Type 0x31
Message Type 0x31
Message Type 0x0001
Message Type 0x31
Message Type 0x31
power.state.enum
Power state
Message Type 0x0001
product.model.enum
Product model
Message Type 0x0011
Message Type 0x0011
Message Type 0x0001
Message Type 0x31
Message Type 0x31
Message Type 0x0011,
Message Type 0x31
total.idle.time
Message Type 0x31
Message Type 0x0001
vehicle.battery.state
Battery state of the vehicle
Message Type 0x0001
Message Type 0x0001
Message Type 0x0001
wifi.status
Wifi connection status
Message Type 0x0001
zigbee.hardware.version
ZigBee hardware version
Message Type 0x2A
zigbee.status
Zigbee connection status
Message Type 0x0001
Battery charger
bcs_protobuf
Bluetooth power mode
bluetooth_power_protobuf
mode: Bluetooth mode
Device events transmission mask
device_events_transmission_mask_protobuf
gps_fixed: GPS fixed
ignition_event: Ignition event
alarm_mode_status: Alarm mode status
sleep_mode_status: Sleep mode status
alarm_panic_status: Alarm panic status
battery_fail_event: Battery fail event
battery_low_status: Battery low status
gnss_antenna_status: Gnss antenna status
input1_active_event: Input1 active event
input2_active_event: Input2 active event
input3_active_event: Input3 active event
output1_active_event: Output1 active event
output2_active_event: Output2 active event
gsm_jamming_alarm_status: Gsm jamming alarm status
configuration_change_event: Configuration change event
external_powersource_status: External powersource status
File command
file_command
file_id: File ID
file_type: File type
file_uuid: CDN File UUID
Digital Outputs Control
inputs_protobuf
status: Status
out_num: Output number
LBS data sending configuration
lbs_protobuf
mode: LBS config
Led mode control
led_protobuf
mode: Enable Panic mode
Low power config
low_power_protobuf
turn_off_rs: Turn off RS-232 on low power
only_battery_mode: Only battery mode
time_before_sleep: Time before sleep
time_before_low_power: Time before low power
network_protobuf
Position Interval Timers
position_interval_protobuf
panic: Panic
sleep: Sleep
jammer: Jammer
battery: Battery
low_power: Low power
portable_moving: Portable moving
portable_stopped: Portable stopped
distance_threshold: Distance threshold
ignition_on_moving: Ignition ON moving
ignition_off_moving: Ignition OFF moving
ignition_on_stopped: Ignition ON stopped
ignition_off_stopped: Ignition OFF stopped
direction_angle_threshold: Direction angle threshold
Primary Server Connection Setup
primary_server_protobuf
Primary server parameters where the monitoring data will be transmitted to
conn_type: Connection type
protobuf_info
iccid1: ICCID SIM 1
iccid2: ICCID SIM 2
Restart the Device by SMS
reboot_protobuf
Secondary Server Connection Setup
secondary_server_protobuf
Connection Server Setup over SMS
server_protobuf_sms
Server parameters where the monitoring data will be transmitted to delivered via SMS
host1: Primary host
host2: Secondary host
port1: Primary port
port2: Secondary port
conn_type1: Primary connection type
conn_type2: Connection type
Set Password
set_password_protobuf
password_new: Password new
password_old: Password old
password_type: Password type
Speeds configuration
speeds_config_protobuf
max_speed: Max speed
hist_slots_qty: Histogram slots quantity
hist_slots_size: Histogram slots size
max_rainy_speed: Max rainy speed
min_speed_on_neutral: Min speed on neutral
User config
user_cfg_protobuf
accept: Accept any user
generate_logout: Ignition off generate logout
Telemetry Variables
variables_protobuf
odometer: Odometer
odometer_can: Odometer CAN
odometer_pulse: Odometer Pulse
vehicle_operation_time: Vehicle operation time
Custom binary command
custom_binary
Custom protobuf command
custom_protobuf
