OMNI OGB1 E-bike
OMNI OGB1 E-bike OMNI is a smart sharing bicycle lock with GPS, GPRS, and Bluetooth support. The device features a 6000mAh/8000mAh battery, waterproof IP67-compliant casing, optional solar panel, and more.
Parameters (70)
Settings (11)
OMNI OGB1 E-bike
Flespi parses telemetry data from your OMNI OGB1 E-bike into a standardized JSON and lets you send commands to OMNI OGB1 E-bike via API.
    "device.type.id": "OMNI OGB1 E-bike",
    "protocol.id": "omni"
How to send commands to OMNI OGB1 E-bike?
Instruction type W0
Instruction type S5
Instruction type H0,
Instruction type S6
Instruction type D0,
Instruction type D1,
Instruction type D3,
Instruction type Q0,
Instruction type S5,
Instruction type S6
Instruction type L6
Instruction type W0
battery.serial
Scooter battery serial number
Instruction type L6
Instruction type S6
Instruction type B0
Instruction type S5
Instruction type M1
Instruction type M1
disassemble.alarm.status
Illegal disassembling alarm event status
Instruction type W0
ecu.error.code
ECU error code
Instruction type E0,
Instruction type E1
Instruction type S6
error.type.description
Error type 1,
Error type 10,
Error type 11,
Error type 13,
Error type 3,
Error type 4,
Error type 6
event.duration
Telemetry event duration
Instruction type L1
Instruction type S1,
Instruction type W0,
Instruction type W1
external.equipment.state
External equipment state
Instruction type L5
external.equipment.type
External equipment type
Instruction type L5
fall.alarm.status
Fall alarm status
Instruction type W0
firmware.type
Firmware type
Instruction type U2
Instruction type U2,
Instruction type U6
Instruction type Q0
Instruction type Q0
Instruction type Q0
Instruction type S6
Instruction type S5
Instruction type W0
indication.mode
Instruction type D3
Instruction type L0,
Instruction type L1,
Instruction type S6
Instruction type W0
parking.lock.lever.state
Parking lock lever arm position (horizontal=unlock, upright=lock, other)
Instruction type S5
Instruction type S5
parking.lock.vehicle.present.status
Vehicle presence detection over parking spot
Instruction type S5
Instruction type K0,
Instruction type U0,
Instruction type U3,
Instruction type Z0
Instruction type D3
Instruction type D3
Instruction type D3
Instruction type D3
Instruction type S5
Instruction type S6
Instruction type D3
reboot.event
Device reboot event
Instruction type Q38
Instruction type S6
Instruction type C0
rfid.card.type
RFID card type
Instruction type C0
Instruction type C0
Instruction type U0
speed.mode
Instruction type S6
Instruction type B0,
Instruction type S6
Instruction type L1
Instruction type S6
unlock.timestamp
Instruction type L1
upgrade.status.name
Upgrade status
Instruction type U6
upgrade.type
Upgrade type
Instruction type U5,
Instruction type U6
Instruction type S6
Instruction type D2
Instruction type D2
D1 Positioning tracking commands
d1_ogb1
upload_interval: Upload positioning interval
K0 BLE communication key
k0_ogb1
value: BLE Key
L0 Unlock instruction
l0
user_id: User ID
reset_riding_time: Reset riding time
L3 Electric vehicle switch control
l3
power: Power
L6 Obtain battery info
l6
S1 Restart
s1_ogb1
S4 Electric vehicle setting instructions
s4_ogb1
lock_motor: Lock motor
speed_mode: Speed mode setting
start_mode: Start mode setting
S5 Access to Lock Information
s5_ogb1
S6 Obtain electric bike information
s6_ogb1
S7 Lock Function Settings
s7_ogb1
sound_alarm: Number of detected movements for sound alarm
command_alarm: Number of detected movements for command alarm
bluetooth_unlock: Bluetooth unlock function
s6_upload_interval: E-bike information (S6) upload interval
active_upload_positioning_interval: Active upload positioning interval
S8 bike search instructions
s8
ring_times: Ring times
payload: Comma separated list of parameters to send as payload
D0 - Get position instruction
{"instruction_type":"D0"}
I0 - Get the SIM card ICCID number
{"instruction_type":"I0"}
S6 - Obtain scooter information command
{"instruction_type":"S6"}
D1 Upload positioning interval 60 seconds
{"payload":"60","instruction_type":"D1"}
V0 Beep playback commands: 2: Find a scooter alert
{"payload":"2","instruction_type":"V0"}
S7 Scooter setting instruction 1 command: headlight switch ON, mode high speed, throttle ignore, taillights flashing shut down
{"payload":"1,3,0,1","instruction_type":"S7"}
