OMNI OT303BL
OMNI OT303BL is a new sharing scooter with LTE support. The device features anti-theft protection, built-in smart lock, GPS+GLONASS/GPS+BDS connectivity, IPX7 rating, 900mAh battery, and more.
Parameters (70)
Settings (13)
OMNI OT303BL
Flespi parses telemetry data from your OMNI OT303BL into a standardized JSON and lets you send commands to OMNI OT303BL via API.
    "device.type.id": "OMNI OT303BL",
    "protocol.id": "omni"
How to send commands to OMNI OT303BL?
Instruction type W0
Instruction type S5
Instruction type H0,
Instruction type S6
Instruction type D0,
Instruction type D1,
Instruction type D3,
Instruction type Q0,
Instruction type S5,
Instruction type S6
Instruction type L6
Instruction type W0
battery.serial
Scooter battery serial number
Instruction type L6
Instruction type S6
Instruction type B0
Instruction type S5
Instruction type M1
Instruction type M1
disassemble.alarm.status
Illegal disassembling alarm event status
Instruction type W0
ecu.error.code
ECU error code
Instruction type E0,
Instruction type E1
Instruction type S6
error.type.description
Error type 1,
Error type 10,
Error type 11,
Error type 13,
Error type 3,
Error type 4,
Error type 6
event.duration
Telemetry event duration
Instruction type L1
Instruction type S1,
Instruction type W0,
Instruction type W1
external.equipment.state
External equipment state
Instruction type L5
external.equipment.type
External equipment type
Instruction type L5
fall.alarm.status
Fall alarm status
Instruction type W0
firmware.type
Firmware type
Instruction type U2
Instruction type U2,
Instruction type U6
Instruction type Q0
Instruction type Q0
Instruction type Q0
Instruction type S6
Instruction type S5
Instruction type W0
indication.mode
Instruction type D3
Instruction type L0,
Instruction type L1,
Instruction type S6
Instruction type W0
parking.lock.lever.state
Parking lock lever arm position (horizontal=unlock, upright=lock, other)
Instruction type S5
Instruction type S5
parking.lock.vehicle.present.status
Vehicle presence detection over parking spot
Instruction type S5
Instruction type K0,
Instruction type U0,
Instruction type U3,
Instruction type Z0
Instruction type D3
Instruction type D3
Instruction type D3
Instruction type D3
Instruction type S5
Instruction type S6
Instruction type D3
reboot.event
Device reboot event
Instruction type Q38
Instruction type S6
Instruction type C0
rfid.card.type
RFID card type
Instruction type C0
Instruction type C0
Instruction type U0
speed.mode
Instruction type S6
Instruction type B0,
Instruction type S6
Instruction type L1
Instruction type S6
unlock.timestamp
Instruction type L1
upgrade.status.name
Upgrade status
Instruction type U6
upgrade.type
Upgrade type
Instruction type U5,
Instruction type U6
Instruction type S6
Instruction type D2
Instruction type D2
Bluetooth MAC
bluetooth_mac
Bluetooth MAC address of the IoT device, read with the M0 instruction.
mac: MAC Address
D0 Get positioning instructions, single time
d0
D1 Positioning tracking commands
d1
upload_interval: Upload positioning interval
L5 Unlock external devices
l5
operation: Operation
r0
lock: Lock/Unlock
user_id: User ID
key_time: Key effective time
S1 Event notification command
s1
event_code: Event code
S4 Scooter setting instruction 2
s4
Note: The following settings are saved after power down.
startup_mode: Startup mode setting
inch_speed_display: Inch speed display
key_switch_headlight: Key switch headlight
button_switching_speed_mode: Button switching speed mode
S5 IoT device settings
s5
s6_upload_interval: Scooter information (S6) upload interval
S6 Obtain scooter information
s6
S7 Scooter setting instruction 1
s7
Note: The following setting information is not saved after power-off, and the default value is restored after restarting or unlocking.
mode: Mode setting
taillights_flashing: Taillights flashing
SIM ICCID
sim_iccid
SIM card ICCID, read with the I0 instruction.
iccid: ICCID
V0 Beep playback commands
v0
play_content: Play content
V1 Beep playback setting
v1
lock_beep: Lock beep
alarm_beep: Alarm beep
unlock_beep: Unlock beep
payload: Comma separated list of parameters to send as payload
D0 - Get position instruction
{"instruction_type":"D0"}
I0 - Get the SIM card ICCID number
{"instruction_type":"I0"}
S6 - Obtain scooter information command
{"instruction_type":"S6"}
D1 Upload positioning interval 60 seconds
{"payload":"60","instruction_type":"D1"}
V0 Beep playback commands: 2: Find a scooter alert
{"payload":"2","instruction_type":"V0"}
S7 Scooter setting instruction 1 command: headlight switch ON, mode high speed, throttle ignore, taillights flashing shut down
{"payload":"1,3,0,1","instruction_type":"S7"}
