Segway Ninebot PJ22IOT
Segway Ninebot PJ22IOT is an IoT device for shared scooter management. The device allows to lock/unlock, power on /off, turn on/off the throttle, and switch between different riding modes, etc. You can also monitor the state of the scooter through its communications with the server, such as sending alarms, firmware version information, battery temperatures, etc. It also has auxiliary features like prompt voice, superior waterproof design (IP67), and a built-in 1000 mAh battery.
Parameters (104)
Settings (9)
Flespi parses telemetry data from your Segway Ninebot PJ22IOT into a standardized JSON and lets you send commands to Segway Ninebot PJ22IOT via API.
    "device.type.id": "Segway Ninebot PJ22IOT",
    "protocol.id": "segway-ninebot"
How to send commands to Segway Ninebot PJ22IOT?
ai.bike.lane.detection.status
AI bike lane detection status
ai.parking.spot.detection.status
AI parking spot detection status
ai.pedestrian.detection.status
AI pedestrian detection status
ai.sidewalk.detection.status
AI sidewalk detection status
alarm.cleared
Alarm cleared event
backup.battery.voltage.status
battery.cell.max.voltage
Maximum voltage of individual battery cell
battery.cell.min.voltage
Minimum voltage of individual battery cell
battery.cell.voltage
Voltage of individual battery cell
battery.charging.cycles
battery.cycle.index
Battery cycle index
battery.design.capacity
Battery design capacity
battery.design.voltage
Battery design voltage
battery.firmware.version
Battery firmware version
battery.number
The number of batteries
battery.type
controller.voltage
Driving voltage of the controller
device.battery.level
Device battery level
device.battery.voltage
display.hardware.version
Display hardware version
ecu.error.code
ECU error code
ecu.sensor.data
Sensor data read from ECU
external.battery.hardware.version
External battery hardware version
fall.alarm.status
Fall alarm status
firmware.type
Firmware type
helmet.box.door.status
Helmet box door opened status
helmet.box.lock.status
Helmet box locked status
helmet.exists.status
Helmet exists status
helmet.uv.status
Helmet ultraviolet rays status
indication.mode
internal.battery.hardware.version
Internal battery hardware version
left.turn.lamp.status
Left turn lamp status - true - on, false - off
motor.power
Electric motor power
nfc.code
NFC card code (UID)
rear.box.lock.status
Rear box lock status
reboot.event
Device reboot event
right.turn.lamp.status
Right turn lamp status - true - on, false - off
seat.lock.status
Seat lock status
seat.occupied.status
Seat occupied status
speed.mode
trip.energy.consumed
Trip energy consumed
unlock.timestamp
vehicle.power
Current vehicle operating power
wheel.lock.processing.status
Wheel lock action in progress
wheel.lock.status
Wheel lock status
I0 Acquire SIM card ICCID number
i0
J0 Light & Detection Config
j0
lock_while_riding: Whether allow force vehicle to lock while riding
sidewalk_indicator: The display logic for Sidewalk indicator on the dashboard
ai_detection_report: AI detection report
default_rear_light_status: The default rear light status when vehicle is unlocked
default_front_light_status: The default front light status when vehicle is unlocked
motor_current_speed_status: Motor current speed status
L5 State of Peripheral Device
l5
operation: Operation
r0
lock: Lock/Unlock
user_id: User ID
key_time: Key effective time
S2 Turn on/off control of scooter
s2
S20 Chassis Ambient light control
s20
mode: Chassis ambient light work mode
color: Chassis ambient light color
S5 IoT Connectivity
s5_zk601le
s6_upload_interval: Scooter information (S6) upload interval
S6 Obtain scooter information
s6
S8 Obtain scooter information
s8
payload: Command payload as comma separated list of parameters
U0 Firmware Upgrade
firmware_upgrade
Upgrade firmware on the device or its components
auth_key: Authentication Key
file_uuid: CDN File UUID
device_type: Device Type
