Segway Scooter IoT 3rd Gen
Segway Gen-3 IoT is an innovative IoT module for shared e-scooters and micromobility. The device features highly precise positioning  dual-band GNSS, ADR and multi-constellation technology), onboard geofencing, high-quality, multi-language audio, flexible interface design, optional Wi-Fi auxiliary positioning, new anti-theft design, IPX7 waterproof casing, Bluetooth 5.0, a small footprint, luminous stickers for night visibility, long standby time with an additional 1000 mAh backup battery and up to 100 working hours, and more.
Parameters (104)
Settings (41)
Flespi parses telemetry data from your Segway Scooter IoT 3rd Gen into a standardized JSON and lets you send commands to Segway Scooter IoT 3rd Gen via API.
    "device.type.id": "Segway Scooter IoT 3rd Gen",
    "protocol.id": "segway-ninebot"
How to send commands to Segway Scooter IoT 3rd Gen?
ai.bike.lane.detection.status
AI bike lane detection status
ai.parking.spot.detection.status
AI parking spot detection status
ai.pedestrian.detection.status
AI pedestrian detection status
ai.sidewalk.detection.status
AI sidewalk detection status
alarm.cleared
Alarm cleared event
backup.battery.voltage.status
battery.cell.max.voltage
Maximum voltage of individual battery cell
battery.cell.min.voltage
Minimum voltage of individual battery cell
battery.cell.voltage
Voltage of individual battery cell
battery.charging.cycles
battery.cycle.index
Battery cycle index
battery.design.capacity
Battery design capacity
battery.design.voltage
Battery design voltage
battery.firmware.version
Battery firmware version
battery.number
The number of batteries
battery.type
controller.voltage
Driving voltage of the controller
device.battery.level
Device battery level
device.battery.voltage
display.hardware.version
Display hardware version
ecu.error.code
ECU error code
ecu.sensor.data
Sensor data read from ECU
external.battery.hardware.version
External battery hardware version
fall.alarm.status
Fall alarm status
firmware.type
Firmware type
helmet.box.door.status
Helmet box door opened status
helmet.box.lock.status
Helmet box locked status
helmet.exists.status
Helmet exists status
helmet.uv.status
Helmet ultraviolet rays status
indication.mode
internal.battery.hardware.version
Internal battery hardware version
left.turn.lamp.status
Left turn lamp status - true - on, false - off
motor.power
Electric motor power
nfc.code
NFC card code (UID)
rear.box.lock.status
Rear box lock status
reboot.event
Device reboot event
right.turn.lamp.status
Right turn lamp status - true - on, false - off
seat.lock.status
Seat lock status
seat.occupied.status
Seat occupied status
speed.mode
trip.energy.consumed
Trip energy consumed
unlock.timestamp
vehicle.power
Current vehicle operating power
wheel.lock.processing.status
Wheel lock action in progress
wheel.lock.status
Wheel lock status
B0 Query Battery Status
b0
C0 Lock/Unlock the battery lock
c0
time: BMS restart time
C1 One-time Vehicle Control
c1
operation_type: Operation type
operation_param: Operation parameter
C2 Mechanical Lock Query
c2
lock_type: Lock type
C3 Mechanical Lock Control
c3
operation: Operation
D0 Query Location
d0
D1 Location tracking command
d1
lock_interval: Lock status upload interval
unlock_interval: Unlock status upload interval
low_bat_interval: Low battery upload interval
temp_lock_interval: Temporary lock status upload interval
temp_low_bat_interval: Temporary low battery upload interval
D2 Tracking Parameters
d2
silence_time: Silence time for illegal-movement dismissal
backup_battery_threshold: Backup battery percentage threshold for D1
G0 Query Firmware Version
g0
G3 Query Extended Firmware Version
g3
I0 Acquire SIM card ICCID number
i0
J0 Light & Detection Config
j0
lock_while_riding: Whether allow force vehicle to lock while riding
sidewalk_indicator: The display logic for Sidewalk indicator on the dashboard
ai_detection_report: AI detection report
default_rear_light_status: The default rear light status when vehicle is unlocked
default_front_light_status: The default front light status when vehicle is unlocked
motor_current_speed_status: Motor current speed status
J1 Status Query
j1
J20 Other settings 2
j20
ecu_wake_up_time: ECU wake up time
auto_lock_timeout: Force vehicle to lock automatically when offline
ai_error_detection: AI Error detection switch for S90L model
ecu_low_power_mode: ECU low power mode
tandem_riding_strategy: Tandem riding detection strategy
tandem_riding_detection: Tandem riding detection switch
J30 Other Settings 3
j30
auto_lock_helmet: Auto-lock helmet lock when inserted
jr4_report_switch: JR4 report switch
jr5_report_switch: JR5 report switch during charging
K0 BLE communication key
k0
value: BLE Key
K1 Secondary BLE communication key
k1
value: BLE Key
L5 Cable Lock Control
l5
M0 Query IoT BLE MAC Address
m0
M1 Query Vehicle Serial Number
m1
N2 eBike Settings
n2
Configure eBike-specific settings including operation modes, lighting, and power assist ratios.
speed_unit: Speed Unit Display
speed_limit: Speed Limit
lighting_mode: Area Indicator Light Mode
operation_mode: Operation Mode
slope_climbing: Slope Climbing Enhancement
rearlight_brake: Rear Light When Braking
headlight_unlock: Headlight When Unlocked
rearlight_unlock: Rear Light When Unlocked
wheel_lock_enable: Wheel Lock Enable
wireless_charging: Wireless Charging When Unlocked
power_assist_ratio: Power Assist Ratio Configuration
ambient_light_effects: Ambient Light Effects Configuration
low_battery_threshold: Low Battery Alarm Threshold
vibration_sensitivity: Vibration Alarm Sensitivity
electronic_wheel_lock_linkage: Electronic Lock and Wheel Lock Linkage
N3 Light Configurations
n3
Configure area indicator lights, rear brake light, ambient light effects, and tube ambient light behavior.
tube_braking: Tube ambient light when braking
tube_turning: Tube ambient light when turning
ambient_modes: Ambient light modes by vehicle status
rear_brake_light: Rear brake light
ambient_frequency: Ambient light effects frequency
area_indicator_modes: Area indicator lighting modes
tube_battery_display: Tube ambient light battery display
area_indicator_frequency: Area indicator flashing frequency
N5 NFC Configuration
n5
Configure NFC module mode and tag data. Mode 1 enables NTag card simulation with custom tag data. Mode 2 enables reading and writing mode.
mode: NFC Mode
tag_data: NFC Tag Data
P2 Request Battery Data
p2
r0
lock: Lock/Unlock
user_id: User ID
key_time: Key effective time
S0 Power Off
s0
Power off scooter and IoT. Only recoverable by plugging in charger.
S1 Reboot
s1
S10 IoT Device Setting 3
s10
left_adc_threshold: Left brake ADC value jump threshold
right_adc_threshold: Right brake ADC value jump threshold
misc_function_bitmask: Miscellaneous function bit mask
brake_anomaly_detection: Brake & accelerator ADC value anomaly detection
accelerator_adc_threshold: Accelerator ADC value jump threshold
left_adc_fallback_threshold: Left brake ADC value fall back to normal threshold
right_adc_fallback_threshold: Right brake ADC value fall back to normal threshold
accelerator_adc_fallback_threshold: Accelerator ADC value fall back to normal threshold
S2 Turn on/off control of scooter
s2
S20 Chassis Ambient light control
s20
mode: Chassis ambient light work mode
color: Chassis ambient light color
S4 Speed Limits & Features
s4
veh_buzzer: Vehicle buzzer
push_assist: Push assist
button_switch: Button switch mode
inch_speed_display: Inch speed display
S5 IoT Connectivity
s5
s6_upload_interval_riding: Scooter information (S6) upload interval during riding
s6_upload_interval_unlocked: Scooter information (S6) upload interval when unlocked
s6_upload_interval_turned_on: Scooter information (S6) upload interval when turned on
S6 Obtain scooter information
s6
S7 Speed & Light Control
s7
mode: Mode setting
rearlight_control: Rear light control
headlight_flashing: Taillights flashing
S8 Obtain scooter information
s8
TS Command Passthrough
ts
Forward HEX command to ECU. Source ID must be 0x3E. No retransmission guarantee.
hex_command: HEX Command
U5 Start upgrade
u5
url: Download URL
type: Upgrade Type 1
timeout: Download timeout
check_code: Check code
permission: Permission
V0 Voice Broadcast Command
v0
content: Content
V1 Device Audio Configuration
v1
mode: Audio Work Mode
normal_volume: Normal volume
abnormal_volume: Abnormal volume
sound_enable_mask: Vehicle sound enable mask
V2 AVAS Configuration
v2
max_volume: Max speed volume
avas_switch: AVAS switch
start_speed: Start speed threshold
start_volume: Volume at start speed
slow_area_only: Only active in SLOW area
mute_over_speed: Max speed threshold to mute AVAS
sidewalk_area_only: Only active in Sidewalk area
pedestrian_detection_only: Only active when Pedestrian detection triggered
V3 Silent Time Periods
v3
silent_volume: Silent time volume
silent_periods: Silent time periods
payload: Command payload as comma separated list of parameters
