Segway Scooter IoT 2nd Gen
Segway Scooter IoT 2nd Gen is an IoT module for sharing scooter solutions.
Parameters (104)
Settings (13)
Flespi parses telemetry data from your Segway Scooter IoT 2nd Gen into a standardized JSON and lets you send commands to Segway Scooter IoT 2nd Gen via API.
    "device.type.id": "Segway Scooter IoT 2nd Gen",
    "protocol.id": "segway-ninebot"
How to send commands to Segway Scooter IoT 2nd Gen?
ai.bike.lane.detection.status
AI bike lane detection status
ai.parking.spot.detection.status
AI parking spot detection status
ai.pedestrian.detection.status
AI pedestrian detection status
ai.sidewalk.detection.status
AI sidewalk detection status
alarm.cleared
Alarm cleared event
backup.battery.voltage.status
battery.cell.max.voltage
Maximum voltage of individual battery cell
battery.cell.min.voltage
Minimum voltage of individual battery cell
battery.cell.voltage
Voltage of individual battery cell
battery.charging.cycles
battery.cycle.index
Battery cycle index
battery.design.capacity
Battery design capacity
battery.design.voltage
Battery design voltage
battery.firmware.version
Battery firmware version
battery.number
The number of batteries
battery.type
controller.voltage
Driving voltage of the controller
device.battery.level
Device battery level
device.battery.voltage
display.hardware.version
Display hardware version
ecu.error.code
ECU error code
ecu.sensor.data
Sensor data read from ECU
external.battery.hardware.version
External battery hardware version
fall.alarm.status
Fall alarm status
firmware.type
Firmware type
helmet.box.door.status
Helmet box door opened status
helmet.box.lock.status
Helmet box locked status
helmet.exists.status
Helmet exists status
helmet.uv.status
Helmet ultraviolet rays status
indication.mode
internal.battery.hardware.version
Internal battery hardware version
left.turn.lamp.status
Left turn lamp status - true - on, false - off
motor.power
Electric motor power
nfc.code
NFC card code (UID)
rear.box.lock.status
Rear box lock status
reboot.event
Device reboot event
right.turn.lamp.status
Right turn lamp status - true - on, false - off
seat.lock.status
Seat lock status
seat.occupied.status
Seat occupied status
speed.mode
trip.energy.consumed
Trip energy consumed
unlock.timestamp
vehicle.power
Current vehicle operating power
wheel.lock.processing.status
Wheel lock action in progress
wheel.lock.status
Wheel lock status
D1 Location tracking command
d1_zk601le
lock_interval: Lock status upload interval
unlock_interval: Unlock status upload interval
I0 Acquire SIM card ICCID number
i0
J0 Light & Detection Config
j0
lock_while_riding: Whether allow force vehicle to lock while riding
sidewalk_indicator: The display logic for Sidewalk indicator on the dashboard
ai_detection_report: AI detection report
default_rear_light_status: The default rear light status when vehicle is unlocked
default_front_light_status: The default front light status when vehicle is unlocked
motor_current_speed_status: Motor current speed status
L5 State of Peripheral Device
l5
operation: Operation
r0
lock: Lock/Unlock
user_id: User ID
key_time: Key effective time
S2 Turn on/off control of scooter
s2
S20 Chassis Ambient light control
s20
mode: Chassis ambient light work mode
color: Chassis ambient light color
S4 Speed Limits & Features
s4_zk601le
inch_speed_display: Inch speed display
S5 IoT Connectivity
s5
s6_upload_interval_riding: Scooter information (S6) upload interval during riding
s6_upload_interval_unlocked: Scooter information (S6) upload interval when unlocked
s6_upload_interval_turned_on: Scooter information (S6) upload interval when turned on
S6 Obtain scooter information
s6
S7 Speed & Light Control
s7
mode: Mode setting
rearlight_control: Rear light control
headlight_flashing: Taillights flashing
S8 Obtain scooter information
s8
V0 Voice Broadcast Command
v0
content: Content
payload: Command payload as comma separated list of parameters
