Segway Ninebot Max Plus X
Segway Ninebot Max Plus X is a high-performance shared electric scooter designed for commercial fleet operations with integrated Gen-3 IoT technology. It features a powerful 400W rated (750W max) motor capable of climbing 14% slopes, dual front suspension system, and 50km range with swappable battery system. The built-in IoT module provides GPS/GLONASS positioning, Bluetooth connectivity, cellular 4G communication, onboard geofencing, and multi-language audio announcements. Designed with fleet efficiency in mind, it offers modular construction with over 12 components replaceable in under 5 minutes. The scooter includes NFC unlocking, optional wireless phone charging, front and rear LED indicators, and IPX4 water resistance for reliable operation in shared mobility applications.
Parameters (104)
Settings (15)
Flespi parses telemetry data from your Segway Ninebot Max Plus X into a standardized JSON and lets you send commands to Segway Ninebot Max Plus X via API.
    "device.type.id": "Segway Ninebot Max Plus X",
    "protocol.id": "segway-ninebot"
How to send commands to Segway Ninebot Max Plus X?
ai.bike.lane.detection.status
AI bike lane detection status
ai.parking.spot.detection.status
AI parking spot detection status
ai.pedestrian.detection.status
AI pedestrian detection status
ai.sidewalk.detection.status
AI sidewalk detection status
alarm.cleared
Alarm cleared event
backup.battery.voltage.status
battery.cell.max.voltage
Maximum voltage of individual battery cell
battery.cell.min.voltage
Minimum voltage of individual battery cell
battery.cell.voltage
Voltage of individual battery cell
battery.charging.cycles
battery.cycle.index
Battery cycle index
battery.design.capacity
Battery design capacity
battery.design.voltage
Battery design voltage
battery.firmware.version
Battery firmware version
battery.number
The number of batteries
battery.type
controller.voltage
Driving voltage of the controller
device.battery.level
Device battery level
device.battery.voltage
display.hardware.version
Display hardware version
ecu.error.code
ECU error code
ecu.sensor.data
Sensor data read from ECU
external.battery.hardware.version
External battery hardware version
fall.alarm.status
Fall alarm status
firmware.type
Firmware type
helmet.box.door.status
Helmet box door opened status
helmet.box.lock.status
Helmet box locked status
helmet.exists.status
Helmet exists status
helmet.uv.status
Helmet ultraviolet rays status
indication.mode
internal.battery.hardware.version
Internal battery hardware version
left.turn.lamp.status
Left turn lamp status - true - on, false - off
motor.power
Electric motor power
nfc.code
NFC card code (UID)
rear.box.lock.status
Rear box lock status
reboot.event
Device reboot event
right.turn.lamp.status
Right turn lamp status - true - on, false - off
seat.lock.status
Seat lock status
seat.occupied.status
Seat occupied status
speed.mode
trip.energy.consumed
Trip energy consumed
unlock.timestamp
vehicle.power
Current vehicle operating power
wheel.lock.processing.status
Wheel lock action in progress
wheel.lock.status
Wheel lock status
G0 Query Firmware Version
G0
I0 Acquire SIM card ICCID number
i0
K0 BLE communication key
k0
value: BLE Key
M0 Query MAC Address of IoT BLE
m0
M1 Query Scooter SN
m1
N5 NFC Configuration
n5
Configure NFC module mode and tag data. Mode 1 enables NTag card simulation with custom tag data. Mode 2 enables reading and writing mode.
mode: NFC Mode
tag_data: NFC Tag Data
r0
lock: Lock/Unlock
user_id: User ID
key_time: Key effective time
S0 Power off Whole Device
s0
S2 Turn on/off control of scooter
s2
S4 Speed Limits & Features
s4_max_plus_x
push_assist: Power-assisted manual push mode switch
inch_speed_display: Inch speed display
S5 IoT Connectivity
s5
s6_upload_interval_riding: Scooter information (S6) upload interval during riding
s6_upload_interval_unlocked: Scooter information (S6) upload interval when unlocked
s6_upload_interval_turned_on: Scooter information (S6) upload interval when turned on
S6 Obtain scooter information
s6
S7 Speed & Light Control
s7
mode: Mode setting
rearlight_control: Rear light control
headlight_flashing: Taillights flashing
S8 Obtain scooter information
s8
S9 IoT Device Setting 2
s9_max_plus_x
wait_timeout: Wait timeout for lock response
lock_while_riding: Enable lock while riding
lock_due_to_offline: Lock due to long time offline
show_battery_accelerator: Show battery volume if accelerator is twisted while locked
invalid_continuous_movement_alarm: Invalid continuous movement alarm report interval
payload: Command payload as comma separated list of parameters
