Segway Ninebot A200
Segway Ninebot A200 is a shared electric bike designed for urban micromobility fleets with integrated IoT connectivity. The e-bike features a 250W motor, 25 km/h top speed, 120+ km range, 26-inch frame with adjustable saddle height, PU-filled rubber tires, drum brakes, and a swappable waterproof battery compatible with Max Pro and Max Plus e-scooters. The built-in IoT module provides electronic cable lock control, NFC unlocking, wireless phone charging, a multi-function display with battery indicator and cellphone holder, and three pedal-assist modes with automatic slope detection for intelligent power adjustment. The "one-size-fits-all" frame accommodates riders from 155 cm to 188 cm.
Parameters (104)
Settings (19)
Segway Ninebot A200
Flespi parses telemetry data from your Segway Ninebot A200 into a standardized JSON and lets you send commands to Segway Ninebot A200 via API.
    "device.type.id": "Segway Ninebot A200",
    "protocol.id": "segway-ninebot"
How to send commands to Segway Ninebot A200?
ai.bike.lane.detection.status
AI bike lane detection status
ai.parking.spot.detection.status
AI parking spot detection status
ai.pedestrian.detection.status
AI pedestrian detection status
ai.sidewalk.detection.status
AI sidewalk detection status
alarm.cleared
Alarm cleared event
backup.battery.voltage.status
battery.cell.max.voltage
Maximum voltage of individual battery cell
battery.cell.min.voltage
Minimum voltage of individual battery cell
battery.cell.voltage
Voltage of individual battery cell
battery.charging.cycles
battery.cycle.index
Battery cycle index
battery.design.capacity
Battery design capacity
battery.design.voltage
Battery design voltage
battery.firmware.version
Battery firmware version
battery.number
The number of batteries
battery.type
controller.voltage
Driving voltage of the controller
device.battery.level
Device battery level
device.battery.voltage
display.hardware.version
Display hardware version
ecu.error.code
ECU error code
ecu.sensor.data
Sensor data read from ECU
external.battery.hardware.version
External battery hardware version
fall.alarm.status
Fall alarm status
firmware.type
Firmware type
helmet.box.door.status
Helmet box door opened status
helmet.box.lock.status
Helmet box locked status
helmet.exists.status
Helmet exists status
helmet.uv.status
Helmet ultraviolet rays status
indication.mode
internal.battery.hardware.version
Internal battery hardware version
left.turn.lamp.status
Left turn lamp status - true - on, false - off
motor.power
Electric motor power
nfc.code
NFC card code (UID)
rear.box.lock.status
Rear box lock status
reboot.event
Device reboot event
right.turn.lamp.status
Right turn lamp status - true - on, false - off
seat.lock.status
Seat lock status
seat.occupied.status
Seat occupied status
speed.mode
trip.energy.consumed
Trip energy consumed
unlock.timestamp
vehicle.power
Current vehicle operating power
wheel.lock.processing.status
Wheel lock action in progress
wheel.lock.status
Wheel lock status
C0 Unlock Battery Lock
c0
C1 Single-time Vehicle Control
c1
operation_type: Operation type
operation_param: Operation parameter
C3 Unlock Cable Lock
c3
D0 Query Location
d0
D1 Location tracking command
d1
lock_interval: Lock status upload interval
unlock_interval: Unlock status upload interval
G3 Query Firmware Version
g3
I0 Acquire SIM card ICCID number
i0
K0 BLE communication key
k0
value: BLE Key
M0 Query MAC Address of IoT BLE
m0
M3 Query Vehicle SN
m3
N2 E-bike Settings
n2
speed_unit: Speed Unit Display
speed_limit: Maximum Speed Limit
operation_mode: Operation Mode
slope_climbing: Ramp Climbing Boost
rearlight_brake: Taillight When Braking
headlight_unlock: Headlight When Unlocked
rearlight_unlock: Taillight When Unlocked
wireless_charging: Wireless Charging When Unlocked
cable_lock_linkage: Electric Lock and Cable Lock Linkage Locking
ambient_light_effects: Ambient Light Effects Configuration
low_battery_threshold: Main Battery Low Power Alarm Threshold
vibration_sensitivity: Vibration Alarm Sensitivity
mudguard_holder_detection: Cable Lock Mudguard Holder Detection
P2 Query Battery Data
p2
r0
lock: Lock/Unlock
user_id: User ID
key_time: Key effective time
S0 Power off Whole Device
s0
S5 IoT Connectivity
s5
s6_upload_interval_riding: Scooter information (S6) upload interval during riding
s6_upload_interval_unlocked: Scooter information (S6) upload interval when unlocked
s6_upload_interval_turned_on: Scooter information (S6) upload interval when turned on
S6 Obtain scooter information
s6
U5 Start Update
u5
url: Download URL
type: Update type
timeout: Download timeout
check_code: File check code (vehicle firmware and audio file)
permission: Upgrade permission (IoT firmware)
V0 Voice Broadcast Command
v0
content: Content
V1 Device Audio Configuration
v1
mode: Audio Work Mode
normal_volume: Normal volume
abnormal_volume: Abnormal volume
sound_enable_mask: Vehicle sound enable mask
payload: Command payload as comma separated list of parameters
