Teltonika FM6300
Teltonika FM6300 is a 3G GPS tracker for heavy transport monitoring. The device features Dual SIM support, RS232/RS485 serial communication interfaces, CAN data (J1939) support, fuel CAN data (J1708) support, tachograph live data (K-Line) support, remote tachograph data download, 6 1-Wire temperature sensors, 4 digital inputs, 4 digital outputs, 3 analog inputs, 1-Wire iButton, 550 mAh Ni-Mh backup battery, and more.
Settings (6)
Teltonika FM6300
Flespi parses telemetry data from your Teltonika FM6300 into a standardized JSON and lets you send commands to Teltonika FM6300 via API.
    "device.type.id": "Teltonika FM6300",
How to send commands to Teltonika FM6300?
Digital Outputs
outputs
out1: Output 1
out2: Output 2
out3: Output 3
out4: Output 4
setdigout_4
tachocheck
addr: Addr
baud: Baud
ignition: Ignition
tacho_download_source
value: Value
Tachograph ignition source
tacho_ignition_source
value: Value
Tacho WEB settings
tacho_web
config: Command mode
{"text":"getrecord"}
Request tachograph file
request_tachograph_file
