Teltonika GH5200
Teltonika GH5200 is an autonomous personal tracker with GNSS, GSM, and Bluetooth connectivity. The device features two-way voice communication, man-down detection, 5 configurable buttons, alarm button, Bluetooth 4.0 + LE, 1050 mAh  Li-Ion battery.
Settings (53)
Teltonika GH5200
Flespi parses telemetry data from your Teltonika GH5200 into a standardized JSON and lets you send commands to Teltonika GH5200 via API.
    "device.type.id": "Teltonika GH5200",
How to send commands to Teltonika GH5200?
Accelerometer delay
accelerometer_delay
Authorized beacons list
auth_beacons
id1: BLE Beacon UID 1
id2: BLE Beacon UID 2
id3: BLE Beacon UID 3
id4: BLE Beacon UID 4
id5: BLE Beacon UID 5
id6: BLE Beacon UID 6
id7: BLE Beacon UID 7
id8: BLE Beacon UID 8
id9: BLE Beacon UID 9
id10: BLE Beacon UID 10
id11: BLE Beacon UID 11
id12: BLE Beacon UID 12
id13: BLE Beacon UID 13
id14: BLE Beacon UID 14
id15: BLE Beacon UID 15
id16: BLE Beacon UID 16
id17: BLE Beacon UID 17
id18: BLE Beacon UID 18
id19: BLE Beacon UID 19
id20: BLE Beacon UID 20
id21: BLE Beacon UID 21
id22: BLE Beacon UID 22
id23: BLE Beacon UID 23
id24: BLE Beacon UID 24
id25: BLE Beacon UID 25
Axis X
axis_x
Axis X parameters settings
avg: Average
low: Low Level
high: High Level
prio: Priority
Axis Y
axis_y
Axis Y parameters settings
avg: Average
low: Low Level
high: High Level
prio: Priority
Axis Z
axis_z
Axis Z parameters settings
avg: Average
low: Low Level
high: High Level
prio: Priority
Secondary GPRS Server Setup
backup_server
Beacon settings
beacon
record: Beacon Records
detection: Beacon detection
BLE common settings
ble_common
Bluetooth work mode
local_name: Local name
security_mode: Security mode
bluetooth_auto_connect
mode: Connection mode
external_mac: External Mac
external_pin: External PIN
external_name: External name
Bluetooth home zone and proximity
bluetooth_features
Allows to set up proximity detection application
rssi: Lowest RSSI before alarm event
scenario: Scenario
pre_alarm: Pre-alarm duration
generate_event: Generate event
proximity_detection: Proximity detection
Restart (reboot) the device
cpureset
data_codec
codec: Data codec
Delete all stored records
deleterecords
Event button source configuration
event_button_source
Configures which buttons trigger events
alarm: Alarm
power: Power
button1: Button 1
button2: Button 2
button3: Button 3
Keyboard feature configuration
feature
Configures keyboard feature priority
fota
web: Enable
getgps
Send getimeiccid command
getimeiccid
getrecord
mac: Bluetooth MAC Address
GNSS Source
gnss_source
gprs
enabled: GPRS Enabled
GPRS Server Setup
gprs_server
protocol: Server protocol
Phone Numbers
gsm_numbers
Predefined GSM phone numbers
phone1: Phone Number 1
phone2: Phone Number 2
phone3: Phone Number 3
phone4: Phone Number 4
phone5: Phone Number 5
phone6: Phone Number 6
phone7: Phone Number 7
phone8: Phone Number 8
phone9: Phone Number 9
phone10: Phone Number 10
Ignition Detection Source
ignition_detection
ign: Ignition Source
Incoming call action
incoming_call
LED Indication
led_indication
enabled: Enabled
Network Time Protocol server
ntp_server
ntp_server1: NTP Server 1
ntp_server2: NTP Server 2
Permanent Link
permalink
Permanent Link
Format SD card
sdformat
SMS Event 1
sms_event1
avl_id: SMS Event AVL ID
event_text: SMS Event Text
gsm_number: GSM Number ID
SMS Event 10
sms_event10
SMS Event 2
sms_event2
SMS Event 3
sms_event3
SMS Event 4
sms_event4
SMS Event 5
sms_event5
SMS Event 6
sms_event6
SMS Event 7
sms_event7
SMS Event 8
sms_event8
SMS Event 9
sms_event9
SMS report sending parameters
sms_reports
Static Navigation
static_filter
stat_nav: Static Navigation
SMS event Time Zone
timezone_sms
Enable connection over TLS
tls
enable: TLS enable
Unknown GSM Network Settings
unknown_network
Set user ID message parameter
user_id
User ID feature allows users to send custom number as AVL ID 854 parameter.
prio: Priority
web_connect
{"text":"getver"}
