Teltonika TST100
Teltonika TST100 is a scooter GPS tracker currently working with Segway and Xiaomi e-scooters. The device can read data from scooters ECU, update firmware and configuration over the air, has IP65 casing, 170 mAh Li-Ion battery, and more. The TST100 functionality includes fall-down detection, jamming detection, unplug detection, auto geofence, manual geofence, trip start and stop detection, engine power on/off, lock/unlock scooter, lights on/off/blink mode selection, siren on/off/beep, speed limit setup, acceleration speed setup, and more.
Settings (84)
Teltonika TST100
Flespi parses telemetry data from your Teltonika TST100 into a standardized JSON and lets you send commands to Teltonika TST100 via API.
    "device.type.id": "Teltonika TST100",
How to send commands to Teltonika TST100?
Accelerometer delay
accelerometer_delay
Analog Input 1 I/O
analog_input1_io
avg: Average
low: Low Level
high: High Level
prio: Priority
Authorized beacons list
auth_beacons
id1: BLE Beacon UID 1
id2: BLE Beacon UID 2
id3: BLE Beacon UID 3
id4: BLE Beacon UID 4
id5: BLE Beacon UID 5
id6: BLE Beacon UID 6
id7: BLE Beacon UID 7
id8: BLE Beacon UID 8
id9: BLE Beacon UID 9
id10: BLE Beacon UID 10
id11: BLE Beacon UID 11
id12: BLE Beacon UID 12
id13: BLE Beacon UID 13
id14: BLE Beacon UID 14
id15: BLE Beacon UID 15
id16: BLE Beacon UID 16
id17: BLE Beacon UID 17
id18: BLE Beacon UID 18
id19: BLE Beacon UID 19
id20: BLE Beacon UID 20
id21: BLE Beacon UID 21
id22: BLE Beacon UID 22
id23: BLE Beacon UID 23
id24: BLE Beacon UID 24
id25: BLE Beacon UID 25
Axis X
axis_x
Axis X parameters settings
avg: Average
low: Low Level
high: High Level
prio: Priority
Axis Y
axis_y
Axis Y parameters settings
avg: Average
low: Low Level
high: High Level
prio: Priority
Axis Z
axis_z
Axis Z parameters settings
avg: Average
low: Low Level
high: High Level
prio: Priority
Secondary GPRS Server Setup
backup_server
Battery charge mode
battery_charge_mode
Battery level
battery_level_io
avg: Average
low: Low Level
high: High Level
prio: Priority
Battery voltage
battery_voltage_io
avg: Average
low: Low Level
high: High Level
prio: Priority
Beacon settings
beacon
record: Beacon Records
detection: Beacon detection
BLE common settings
ble_common
Bluetooth work mode
local_name: Local name
security_mode: Security mode
bluetooth_auto_connect
mode: Connection mode
external_mac: External Mac
external_pin: External PIN
external_name: External name
Bluetooth Lock
bt_lock
Bluetooth lock configuration
lock: Enable
Unlock Bluetooth Lock
bt_unlock
Restart (reboot) the device
cpureset
data_codec
codec: Data codec
Delete all stored records
deleterecords
External voltage
external_voltage_io
avg: Average
low: Low Level
high: High Level
prio: Priority
fota
web: Enable
getgps
Send getimeiccid command
getimeiccid
getrecord
mac: Bluetooth MAC Address
GNSS Source
gnss_source
gprs
enabled: GPRS Enabled
GPRS Server Setup
gprs_server
protocol: Server protocol
Phone Numbers
gsm_numbers
Predefined GSM phone numbers
phone1: Phone Number 1
phone2: Phone Number 2
phone3: Phone Number 3
phone4: Phone Number 4
phone5: Phone Number 5
phone6: Phone Number 6
phone7: Phone Number 7
phone8: Phone Number 8
phone9: Phone Number 9
phone10: Phone Number 10
Ignition Detection Source
ignition_detection
ign: Ignition Source
Incoming call action
incoming_call
jamming_timeout
mode: Scenario priority
LED Indication
led_indication
enabled: Enabled
Motion Detection Source
motion_detection
can: CAN Speed
gps: GPS
ignition: Ignition
movement: Movement sensor
Network Time Protocol server
ntp_server
ntp_server1: NTP Server 1
ntp_server2: NTP Server 2
odometer_io
Enable odometer
low: Low Level
high: High Level
prio: Priority
Digital Output
outputs1
out1: Output
Permanent Link
permalink
Permanent Link
Open battery lock for battery replacement
scbatopen
Command works only with Segway MAX scooters with replaceable batteries
IoT buzzer control.
scbuzzerctrl
Command works only with Segway ES/MAX/Xiaomi M365
mode: switch
timeout: timeout
Scooter Cable Unlock (Experimental)
sccableunlock
Start or shut down the scooter engine
scenginectrl
mode: switch
E-Scooter's firmware force update
sciap
arg: Argument
Lock/Unlock Scooter. Is available only in non-riding mode
sclockctrl
lock: Lock/Unlock
Looking for scooter
sclookfor
headlight and taillight will flash and beep
mode: switch
Scooter fall down event alarm
scooter_fall_down
fall_down: Enable event report
Turn on/off scooter using PCW (Power Control Wire)
scpowerctrl
Effect of command and response depends on scooter state at the time of receiving a command.
Shut down scooter
scpoweroff
shut down is done using inner command sent to scooter main board
Restart scooter system
screbootsys
Scooter beep control on alarm
scsetalarmswitch
mode: switch
Scooter beep control switch
scsetbeepswitch
mode: switch
Set scooter BT pairing code
scsetbtcode
code: BT code
Scooter functions setup. 1st instruction set
scsetconfig1
use_mph: Use mph units
error_icon: Error icon on or off
broadcast_bt: Bluetooth broadcast or not
display_unit: Display unit or not
bt_icon_flash: Bluetooth icon flash or off
display_panel: Panel display or not
display_speed: Display speed or not
ext_bat_light: External battery light on/off
bt_icon_always: Bluetooth icon always on or off
headlight_flash: Headlight flash
no_alarm_locked: No alarm when locked
taillight_flash: Taillight flash
headlight_always: Headlight always on/off
taillight_always: Taillight always on/off
display_bat_level: Display battery level on or off
temperature_icon_error: Temperature error icon on or off
Scooter functions setup. 2nd instruction set
scsetconfig2
button_change_mode: Button can change mode or not
display_speed_change: Display speed mode or not
Scooter cruise control switch
scsetcruiseswitch
mode: switch
Scooter headlight switch
scsetledswitch
mode: switch
Set scooter operating mode
scsetmode
mode: Operating mode
Scooter Speed Limit Normal
scsetspdlim0
Set E-Scooter speed limit for Normal mode
limit: Limit
Scooter Speed Limit Eco
scsetspdlim1
Set E-Scooter speed limit for Eco mode
limit: Limit
Scooter Speed Limit Sport
scsetspdlim2
Set E-Scooter speed limit for Sport mode
limit: Limit
Format SD card
sdformat
setdigout_1
SMS Event 1
sms_event1
avl_id: SMS Event AVL ID
event_text: SMS Event Text
gsm_number: GSM Number ID
SMS Event 10
sms_event10
SMS Event 2
sms_event2
SMS Event 3
sms_event3
SMS Event 4
sms_event4
SMS Event 5
sms_event5
SMS Event 6
sms_event6
SMS Event 7
sms_event7
SMS Event 8
sms_event8
SMS Event 9
sms_event9
SMS report sending parameters
sms_reports
Static Navigation
static_filter
stat_nav: Static Navigation
SMS event Time Zone
timezone_sms
Enable connection over TLS
tls
enable: TLS enable
Trip Odometer
trip_odometer_io
low: Low Level
high: High Level
prio: Priority
Unknown GSM Network Settings
unknown_network
web_connect
{"text":"getrecord"}
