Xexun DDX15
Curfew Base Station DDX15 is a professional-grade wearable tracking device for community corrections and special industry applications. It features two-way UWB high-precision ranging with GPS ankle devices, real-time 4G data transmission, vibration and low power alarms, fingerprint recognition, two-way conversation, remote audio monitoring, remote upgrade, and a 4000mAh rechargeable battery. The device offers up to 36 hours standby time, motion detection, and operates in extreme temperatures, making it suitable for secure and reliable monitoring.
Parameters (134)
Xexun DDX15
Flespi parses telemetry data from your Xexun DDX15 into a standardized JSON and lets you send commands to Xexun DDX15 via API.
    "device.type.id": "Xexun DDX15",
    "protocol.id": "xexun"
How to send commands to Xexun DDX15?
acc.alarm
ACC alarm event
arm.status
battery.balanced.status
Battery balanced status
battery.capacity
Nominal battery capacity
Charge overcurrent status
battery.charge.switch.status
Battery charge switch status
battery.cycle.index
Battery cycle index
Discharge overcurrent status
battery.drop.line.status
Battery drop line status
battery.equalization.accuracy
mV
Battery equalization accuracy
battery.equalization.voltage
battery.low.capacity.status
Low capacity status
MOS ultra-temperature status
battery.number
The number of batteries
battery.overheating.status
battery.recovery.temperature
battery.temperature.probes
Battery temperature probes
blood.oxygen.saturation
Blood oxygen saturation SpO2
blood.pressure.diastolic
mm/Hg
Diastolic blood pressure
blood.pressure.systolic
mm/Hg
Systolic blood pressure
can.onboard.power.voltage
CAN onboard power voltage
equilibrium.plate.temperature
Equilibrium.plate.temperature
fuel.alarm
Fuel alarm event
gps.average.snr
gps.max.snr
gps.module.version
GPS module version
gsm.firmware.version
heart.rate
bpm
Heart rate
log.data
Log Entry Report Log Data
log.data.type
Log Entry Report Data Type ID
low.speed.alarm
motor.locked.status
Motor locked status
power.plate.temperature
Power plate temperature
vehicle.factory.date
vehicle.factory.number
wristband.takeoff.alarm
Wristband take off alarm
Cut OFF restore and electricity of the car [123456 - device password]
{"payload":"powercar123456 11"}
Cut OFF oil and electricity of the car to stop the car [123456 - device password]
{"payload":"powercar123456 00"}
