Xexun X04
Mini GPS Tracker X04 is a compact, portable asset tracker with GPS/Beidou/WIFI/LBS hybrid tracking, real-time and historical location monitoring, virtual fence, blind spot tracking, SOS emergency alarm, remote listening, low power alarm, and remote upgrade. It features 2G/3G/4G connectivity, a rechargeable 600mAh battery, and a user-friendly cloud platform and mobile app. The device is lightweight, made from environmentally friendly plastic, and suitable for personal, pet, or asset tracking.
Parameters (134)
Xexun X04
Flespi parses telemetry data from your Xexun X04 into a standardized JSON and lets you send commands to Xexun X04 via API.
    "device.type.id": "Xexun X04",
    "protocol.id": "xexun"
How to send commands to Xexun X04?
acc.alarm
ACC alarm event
arm.status
battery.balanced.status
Battery balanced status
battery.capacity
Nominal battery capacity
Charge overcurrent status
battery.charge.switch.status
Battery charge switch status
battery.cycle.index
Battery cycle index
Discharge overcurrent status
battery.drop.line.status
Battery drop line status
battery.equalization.accuracy
mV
Battery equalization accuracy
battery.equalization.voltage
battery.low.capacity.status
Low capacity status
MOS ultra-temperature status
battery.number
The number of batteries
battery.overheating.status
battery.recovery.temperature
battery.temperature.probes
Battery temperature probes
blood.oxygen.saturation
Blood oxygen saturation SpO2
blood.pressure.diastolic
mm/Hg
Diastolic blood pressure
blood.pressure.systolic
mm/Hg
Systolic blood pressure
can.onboard.power.voltage
CAN onboard power voltage
equilibrium.plate.temperature
Equilibrium.plate.temperature
fuel.alarm
Fuel alarm event
gps.average.snr
gps.max.snr
gps.module.version
GPS module version
gsm.firmware.version
heart.rate
bpm
Heart rate
log.data
Log Entry Report Log Data
log.data.type
Log Entry Report Data Type ID
low.speed.alarm
motor.locked.status
Motor locked status
power.plate.temperature
Power plate temperature
vehicle.factory.date
vehicle.factory.number
wristband.takeoff.alarm
Wristband take off alarm
Cut OFF restore and electricity of the car [123456 - device password]
{"payload":"powercar123456 11"}
Cut OFF oil and electricity of the car to stop the car [123456 - device password]
{"payload":"powercar123456 00"}
