Xexun X01
Car GPS Tracker X01 is an industrial-grade GPS/Beidou tracker for cars, motorcycles, and electric vehicles. It features real-time and interval-based tracking, historical route playback, virtual fence alerts, speeding and low power alarms, blind spot data storage, start/stop detection, remote upgrade, and a 100mAh rechargeable battery. The device supports 2G/3G/4G networks, operates on 9-90V DC, and is managed via a cloud platform and mobile app. Compact and easy to install, it ensures reliable vehicle monitoring in various environments.
Parameters (134)
Xexun X01
Flespi parses telemetry data from your Xexun X01 into a standardized JSON and lets you send commands to Xexun X01 via API.
    "device.type.id": "Xexun X01",
    "protocol.id": "xexun"
How to send commands to Xexun X01?
acc.alarm
ACC alarm event
arm.status
battery.balanced.status
Battery balanced status
battery.capacity
Nominal battery capacity
Charge overcurrent status
battery.charge.switch.status
Battery charge switch status
battery.cycle.index
Battery cycle index
Discharge overcurrent status
battery.drop.line.status
Battery drop line status
battery.equalization.accuracy
mV
Battery equalization accuracy
battery.equalization.voltage
battery.low.capacity.status
Low capacity status
MOS ultra-temperature status
battery.number
The number of batteries
battery.overheating.status
battery.recovery.temperature
battery.temperature.probes
Battery temperature probes
blood.oxygen.saturation
Blood oxygen saturation SpO2
blood.pressure.diastolic
mm/Hg
Diastolic blood pressure
blood.pressure.systolic
mm/Hg
Systolic blood pressure
can.onboard.power.voltage
CAN onboard power voltage
equilibrium.plate.temperature
Equilibrium.plate.temperature
fuel.alarm
Fuel alarm event
gps.average.snr
gps.max.snr
gps.module.version
GPS module version
gsm.firmware.version
heart.rate
bpm
Heart rate
log.data
Log Entry Report Log Data
log.data.type
Log Entry Report Data Type ID
low.speed.alarm
motor.locked.status
Motor locked status
power.plate.temperature
Power plate temperature
vehicle.factory.date
vehicle.factory.number
wristband.takeoff.alarm
Wristband take off alarm
Send a custom command using FAAF framing and wait for a reply
Set tracking parameters
{"payload":"tk=1,60,1,180,1"}
