Xexun X02
Handheld GPS Tracker X02 is an industrial-grade tracker for vehicles, motorcycles, and e-vehicles. It features GPS/Beidou/WIFI/LBS hybrid tracking, real-time and historical tracking, virtual fence, blind spot tracking, disassembly and low power alarms, remote listening, remote upgrade, 4G connectivity, a rechargeable 10000mAh battery, magnetic mount, and a robust cloud management platform. The device is easy to install and offers up to 2 months standby time.
Parameters (134)
Xexun X02
Flespi parses telemetry data from your Xexun X02 into a standardized JSON and lets you send commands to Xexun X02 via API.
    "device.type.id": "Xexun X02",
    "protocol.id": "xexun"
How to send commands to Xexun X02?
acc.alarm
ACC alarm event
arm.status
battery.balanced.status
Battery balanced status
battery.capacity
Nominal battery capacity
Charge overcurrent status
battery.charge.switch.status
Battery charge switch status
battery.cycle.index
Battery cycle index
Discharge overcurrent status
battery.drop.line.status
Battery drop line status
battery.equalization.accuracy
mV
Battery equalization accuracy
battery.equalization.voltage
battery.low.capacity.status
Low capacity status
MOS ultra-temperature status
battery.number
The number of batteries
battery.overheating.status
battery.recovery.temperature
battery.temperature.probes
Battery temperature probes
blood.oxygen.saturation
Blood oxygen saturation SpO2
blood.pressure.diastolic
mm/Hg
Diastolic blood pressure
blood.pressure.systolic
mm/Hg
Systolic blood pressure
can.onboard.power.voltage
CAN onboard power voltage
equilibrium.plate.temperature
Equilibrium.plate.temperature
fuel.alarm
Fuel alarm event
gps.average.snr
gps.max.snr
gps.module.version
GPS module version
gsm.firmware.version
heart.rate
bpm
Heart rate
log.data
Log Entry Report Log Data
log.data.type
Log Entry Report Data Type ID
low.speed.alarm
motor.locked.status
Motor locked status
power.plate.temperature
Power plate temperature
vehicle.factory.date
vehicle.factory.number
wristband.takeoff.alarm
Wristband take off alarm
Send a custom command using FAAF framing and wait for a reply
Set tracking parameters
{"payload":"tk=1,60,1,180,1"}
