The main elements of the flespi panel interface are intuitive, though we continuously work on improving it and adding new useful shortcuts and tabs, or enhancing menus. In this article, we’ll cover some basic UI aspects that might not be immediately noticeable but can simplify certain operations, providing quick access to frequently used features and tools.
The flespi home screen consists of key sections presented as a list on the left, with the main window used to explore the selected items in the center. On the top right, you will find the Agents, Support, Notifications, Open, and Tools buttons.
Agents lists the flespi AI agents of your account and opens the one you pick in AgentBox, the app for your agents. The "+" button creates a new one.
Support opens HelpBox, where you can reach our dev team or meet Codi - our smart AI assistant.
Notifications shows flespi news, changelog posts and other notices, see Notifications.
Open helps you navigate to a specific device/channel/etc. by entering its ID.
Tools provide access to various utilities.
Tools
The Tools pane includes quick access to the following items:
API Playground - A comprehensive reference for using the flespi REST API to interact with the platform from your solutions.
Toolbox - Debug and diagnostic tools for all platform elements, detailed logs, and real-time messages.
Re-register Messages - A tool that allows you to re-register messages for a certain period (applicable with channels, devices, and streams).
Expressions Test Tool - You can construct and test your own expressions with the Expressions Test tool
Expression functions - Here you can find expression functions examples and their descriptions
Message Parameters - All available message parameters for a quick lookup.
TrackIt - GPS tracking tool for your devices, including a map, messages, telemetry, track player, and more.
Setbox - Easy setup of trackers from multiple manufacturers via a single user-friendly interface.
MQTT Board - MQTT client tool for easy MQTT publication/subscription, testing, and demonstration with full MQTT 5.0 support.
MQTT Tiles - MQTT-based IoT dashboard visualization tool, also compliant with MQTT 5.0.
MQTT Topics Directory - All available MQTT topics.
PVM Generator - A simple utility for generating PVM code by describing in human-readable text what it should do.
Recycle Bin - A 30-day grace period to recover items deleted from the current account (excluding items from subaccounts).
Changelogs - The changelogs your account follows, see Changelogs.
Tools that open inside the panel, as well as agent chats and the support chat, come as tabs in the pane on the right. Drag any tab by its title to turn it into a floating window and keep several of them at hand while you work:
Notifications
The Notifications button (bell) opens the notifications panel. It shows:
- flespi news and NOC messages about maintenance and incidents
- new posts from the changelogs you follow, with Forum and Changelog buttons to read more
- a notice when a new panel version is available, with a button to reload the panel
- AI agent operations waiting for your approval
- errors from your actions in the panel
New notifications are on the New tab. Click the archive icon on a notification to move it to the Archive tab, or click the button in the top-left corner of the panel to archive them all. Notifications are kept for 60 days.
By default, the panel opens by itself when a new notification arrives. To keep it closed, turn off the Auto-open toggle at the top of the notifications panel. New notifications then only light up the bell. The same option is on the Notifications tab of panel settings, next to Only notifications from this account, which shows AI agent approvals only for agents of your own account, not for agents of subaccounts and granted accounts.
Changelogs
flespi publishes changes to each platform module, protocol and plugin in changelogs. The panel subscribes your account to the relevant changelogs and shows their new posts in Notifications as soon as they are published:
- the main flespi systems and tools, such as AI and MCP, telematics hub, platform API, MQTT broker, database, analytics, panel and Toolbox
- the protocol of each channel or device you create in the panel
- the protocol of each stream you create in the panel
- the plugin type of each plugin you create in the panel
On your first login, the panel also subscribes you to the protocols of your existing channels and streams and the types of your existing plugins.
Open Tools > Changelogs to read the latest posts of all your subscriptions in one feed. My subscriptions on the right groups them into flespi systems, channel protocols, stream protocols and plugins. Click a group or a changelog to read only its posts, or click the bell icon to unsubscribe. Other changelogs lists the ones you do not follow: click Subscribe to follow one. A few of them, such as the Knowledge Base changelog, are read on the forum only. Each post has an Open forum button.
A changelog you unsubscribed from stays unsubscribed when you create new items. To stop changelog notifications without changing your subscriptions, turn off the Notify toggle at the top of the window. Subscriptions belong to the account, not to the browser. For other ways to follow changes, see How to stay current.
Filter bar
The Filter bar is located at the bottom of the home screen of your flespi panel.
Here you can type any part of an item you’re looking for - if any matches are found, they will show up. Please note that the field will be highlighted in green if your search syntax is correct; otherwise, it remains gray meaning the input is not valid.
The Filter bar provides a quick lookup for any flespi item referring to the section you have previously selected from the main menu on the left. For example, if you click Telematics Hub > Devices and start typing, the search will look for devices parsing their ‘device name’, ‘device ID’, or ‘IMEI’. If any matches are found, the corresponding devices will appear. If you navigated to Telematics Hub > Channels, you’d search for ‘channel ID’, ‘channel name’, ‘host’, and ‘port’. Wildcards are allowed, so if you need a strict search rule, you can enclose the search condition in quotes “...”.
You can find the list of fields in API Playground > Devices. Don’t forget about the exclamation marks wrapping the expression.
Examples of using custom field values:
To show only connected devices: !{connected==true}!
To show only blocked devices: !{blocked==true}!
To see only devices that have the engine running now: !{engine.ignition.status==true}!
To search for devices not connected for longer than 24 hours: !{last_active < (now() - 86400)}!
To show two different devices by their idents: !{configuration.ident in ("545445645465", "00D200B433")}!
To show only devices located no further than 10 km from specific coordinates: !{distance(telemetry.position.latitude, telemetry.position.longitude, 23.9090909, 23.000923) < 10}!
Favorites
This UI option allows you to choose custom menu items to be displayed at the top of the list, providing quick access to the most frequently used menu items. To select an item, click the ‘pencil’ icon to edit, then click the ‘heart’ icon next to any item in the main menu. You can add as many as you like.
You can use the ‘Pin item’ option available in the context menu (right button mouse click) for any of your devices, channels, etc. Pinned items have orange bar on the left side of the item card.
Panel settings
Click your account name in the top-left corner to open panel settings. Each tab has its own green Save button.
- Account - your name, social media login, email, password and company details.
- Billing - contract, plan and payment method (paid plans).
- Appearance - panel color, menu sections, experimental and legacy features, and Restore informational banners to bring back hidden tips.
- Performance - simplify long lists and hide subaccount items in the main lists.
- Notifications - see Notifications.
- Subscriptions - turn the monthly flespi changelog email on or off.
Experimental features
To access functionality marked as experimental in flespi panel you need to activate it first. Open panel settings, navigate to Appearance tab, check Experimental features and click on green Save button to apply it.
After that experimental features will be unlocked in your flespi panel.
