You can obtain telematics data from any Sinocastel device in 6 easy steps:
Set up the Sinocastel channel in your flespi.io interface.
Point a Sinocastel device to your flespi account using the device configurator from Sinocastel or by sending an SMS command to the device.
Access Sinocastel device data via API.
Create a flespi device to access telemetry, apply plugins and analytics, and use long-term message storage.
2. Set up the Sinocastel channel in flespi.io
The Channel dialogue box will show up. Enter the name for the channel (any text will suffice), select “sinocastel” in the protocol_id drop-down menu, click 'SAVE + OPEN'.
You're forwarded to the Channel details box. Make a note of the domain name and port that you should point your device to, it will look like Host: ch#######.flespi.gw and Port:#####.
3. Point your Sinocastel device to your flespi channel
You can use the Sinocastel configurator tool - OBD Smart PC Tools. The Network tab will look like the following:
Alternatively, you can configure the device by sending an SMS command.
While in the Channel dialogue box, click on the Logs & Messages tab. Inspect log records to confirm that your device has successfully connected to flespi. The presence of messages in the lower half of the screen will confirm that the incoming data is parsed. Please keep in mind that as the Logs section runs in realtime it will reflect any connection attempt. Hint: you can right-click on a message or log to show corresponding raw
5. Access Sinocastel device data via API
Make a note of what your Channel ID and click on the API Playground menu item:
Fill in your channel ID in the 1-ch-selector field. Scroll a little lower until you see the 'eye' button and click on it.
6. Create a flespi device
What's next?
