GoSafe GTU-100
GoSafe GTU-100 is a basic vehicle GPS widely used in SVR and fleet management. The device features LTE connectivity, multiple digital I/O, a 1-Wire interface, a 220 mAh battery, dual-SIM support, IP65 waterproof casing, BLE 4.0, and more.
Parameters (158)
GoSafe GTU-100
Flespi parses telemetry data from your GoSafe GTU-100 into a standardized JSON and lets you send commands to GoSafe GTU-100 via API.
    "device.type.id": "GoSafe GTU-100",
    "protocol.id": "gosafe"
How to send commands to GoSafe GTU-100?
accident.event
Accident event detected
Alarm mark bitmask
backup.battery.voltage.status
Alarm mark bitmask
call.status
Call status bit
cornering.acceleration
Cornering acceleration
crash.timestamp
Crash timestamp
device.mode
Device working mode code
Additional info ID 0x2A,
Alarm mark bitmask
flash.storage.status
Flash storage status
frequency.counter.din
fuel.weight
Fuel weight
Alarm mark bitmask
gsm.sim.balance
SIM card balance
hardware.fault.code
Hardware fault code
hardware.malfunction.alert
Alarm mark bitmask
Alarm mark bitmask
harsh.turn.event
Harsh turn event detected
Alarm mark bitmask
Alarm mark bitmask
message.content
Message content
Alarm mark bitmask
position.fix.type
Alarm mark bitmask
Alarm mark bitmask
Alarm mark bitmask
Alarm mark bitmask
Alarm mark bitmask
sensor.status
socket.connection.status
Socket connection status
Alarm mark bitmask
trip.type
Trip type (Private, Business)
turnover.event
Turnover event
Alarm mark bitmask
Alarm mark bitmask
