GoSafe GTU-300
GoSafe GTU-300 is a vehicle GPS tracker for fleet and truck businesses. The device features LTE connectivity multiple digital I/O and analog inputs, RS232/RS485, BLE 4.0 or 5.0, 220 mAh battery, and more.
Parameters (158)
GoSafe GTU-300
Flespi parses telemetry data from your GoSafe GTU-300 into a standardized JSON and lets you send commands to GoSafe GTU-300 via API.
    "device.type.id": "GoSafe GTU-300",
    "protocol.id": "gosafe"
How to send commands to GoSafe GTU-300?
accident.event
Accident event detected
Alarm mark bitmask
backup.battery.voltage.status
Alarm mark bitmask
call.status
Call status bit
cornering.acceleration
Cornering acceleration
crash.timestamp
Crash timestamp
device.mode
Device working mode code
Additional info ID 0x2A,
Alarm mark bitmask
flash.storage.status
Flash storage status
frequency.counter.din
fuel.weight
Fuel weight
Alarm mark bitmask
gsm.sim.balance
SIM card balance
hardware.fault.code
Hardware fault code
hardware.malfunction.alert
Alarm mark bitmask
Alarm mark bitmask
harsh.turn.event
Harsh turn event detected
Alarm mark bitmask
Alarm mark bitmask
message.content
Message content
Alarm mark bitmask
position.fix.type
Alarm mark bitmask
Alarm mark bitmask
Alarm mark bitmask
Alarm mark bitmask
Alarm mark bitmask
sensor.status
socket.connection.status
Socket connection status
Alarm mark bitmask
Message ID 0x0704
trip.type
Trip type (Private, Business)
turnover.event
Turnover event
Alarm mark bitmask
Alarm mark bitmask
