GoSafe GTU-5000
GoSafe GTU-5000 is a commercial fleet telematics device with LTE connectivity. The device features multiple serial ports, BLE 4.2, 1-Wire, TTL/RS232/RS485, dual-SIM support, 950 mAh battery, and more.
Parameters (158)
GoSafe GTU-5000
Flespi parses telemetry data from your GoSafe GTU-5000 into a standardized JSON and lets you send commands to GoSafe GTU-5000 via API.
    "device.type.id": "GoSafe GTU-5000",
    "protocol.id": "gosafe"
How to send commands to GoSafe GTU-5000?
accident.event
Accident event detected
Alarm mark bitmask
backup.battery.voltage.status
Alarm mark bitmask
call.status
Call status bit
cornering.acceleration
Cornering acceleration
crash.timestamp
Crash timestamp
device.mode
Device working mode code
Additional info ID 0x2A,
Alarm mark bitmask
flash.storage.status
Flash storage status
frequency.counter.din
fuel.weight
Fuel weight
Alarm mark bitmask
gsm.sim.balance
SIM card balance
hardware.fault.code
Hardware fault code
hardware.malfunction.alert
Alarm mark bitmask
Alarm mark bitmask
harsh.turn.event
Harsh turn event detected
Alarm mark bitmask
Alarm mark bitmask
message.content
Message content
Alarm mark bitmask
position.fix.type
Alarm mark bitmask
Alarm mark bitmask
Alarm mark bitmask
Alarm mark bitmask
Alarm mark bitmask
sensor.status
socket.connection.status
Socket connection status
Alarm mark bitmask
trip.type
Trip type (Private, Business)
turnover.event
Turnover event
Alarm mark bitmask
Alarm mark bitmask
