OMNI Smart Parking Lock
OMNI Smart Parking Lock is an intelligent parking reservation and space management device for personal and shared car parks. It supports BLE for personal use and options with 4G LTE, NB-IoT, or RS485 for shared and gateway-managed deployments. The lock features automatic control via mobile app or server, IP67 waterproof aluminum alloy housing, and flexible power options including 1.5V cells or 6V lead-acid batteries. Designed for fixed parking spaces, it operates from -10°C to +60°C, enabling smart parking systems and remote access control in commercial and residential lots.
Parameters (70)
Settings (6)
Flespi parses telemetry data from your OMNI Smart Parking Lock into a standardized JSON and lets you send commands to OMNI Smart Parking Lock via API.
    "device.type.id": "OMNI Smart Parking Lock",
    "protocol.id": "omni"
How to send commands to OMNI Smart Parking Lock?
Instruction type W0
Instruction type S5
Instruction type H0,
Instruction type S6
Instruction type D0,
Instruction type D1,
Instruction type D3,
Instruction type Q0,
Instruction type S5,
Instruction type S6
Instruction type L6
Instruction type W0
battery.serial
Scooter battery serial number
Instruction type L6
Instruction type S6
Instruction type B0
Instruction type S5
Instruction type M1
Instruction type M1
disassemble.alarm.status
Illegal disassembling alarm event status
Instruction type W0
ecu.error.code
ECU error code
Instruction type E0,
Instruction type E1
Instruction type S6
error.type.description
Error type 1,
Error type 10,
Error type 11,
Error type 13,
Error type 3,
Error type 4,
Error type 6
event.duration
Telemetry event duration
Instruction type L1
Instruction type S1,
Instruction type W0,
Instruction type W1
external.equipment.state
External equipment state
Instruction type L5
external.equipment.type
External equipment type
Instruction type L5
fall.alarm.status
Fall alarm status
Instruction type W0
firmware.type
Firmware type
Instruction type U2
Instruction type U2,
Instruction type U6
Instruction type Q0
Instruction type Q0
Instruction type Q0
Instruction type S6
Instruction type S5
Instruction type W0
indication.mode
Instruction type D3
Instruction type L0,
Instruction type L1,
Instruction type S6
Instruction type W0
parking.lock.lever.state
Parking lock lever arm position (horizontal=unlock, upright=lock, other)
Instruction type S5
Instruction type S5
parking.lock.vehicle.present.status
Vehicle presence detection over parking spot
Instruction type S5
Instruction type K0,
Instruction type U0,
Instruction type U3,
Instruction type Z0
Instruction type D3
Instruction type D3
Instruction type D3
Instruction type D3
Instruction type S5
Instruction type S6
Instruction type D3
reboot.event
Device reboot event
Instruction type Q38
Instruction type S6
Instruction type C0
rfid.card.type
RFID card type
Instruction type C0
Instruction type C0
Instruction type U0
speed.mode
Instruction type S6
Instruction type B0,
Instruction type S6
Instruction type L1
Instruction type S6
unlock.timestamp
Instruction type L1
upgrade.status.name
Upgrade status
Instruction type U6
upgrade.type
Upgrade type
Instruction type U5,
Instruction type U6
Instruction type S6
Instruction type D2
Instruction type D2
R0 Lock/Unlock operation request
r0_parking_lock
Send R0 command to request operation key. After device responds, L0 or L1 command will be sent automatically.
lock: Lock/Unlock
user_id: User ID
key_time: Key effective time (seconds)
S1 Restart
s1_parking_lock
Restart the parking lock device.
S3 Server address
s3_parking_lock
Modify the server address that the parking lock connects to.
server_port: Server port
server_address: Server IP or domain
S5 Device status
s5_parking_lock
Query device information and status. Response is parsed as a telemetry message.
S6 Auto-lock
s6_parking_lock
Enable or disable automatic locking feature.
auto_lock: Auto-lock enabled
S8 Lock finding
s8_parking_lock
Trigger lock finding alarm to help locate the parking lock.
payload: Comma separated list of parameters to send as payload
D0 - Get position instruction
{"instruction_type":"D0"}
I0 - Get the SIM card ICCID number
{"instruction_type":"I0"}
S6 - Obtain scooter information command
{"instruction_type":"S6"}
D1 Upload positioning interval 60 seconds
{"payload":"60","instruction_type":"D1"}
V0 Beep playback commands: 2: Find a scooter alert
{"payload":"2","instruction_type":"V0"}
S7 Scooter setting instruction 1 command: headlight switch ON, mode high speed, throttle ignore, taillights flashing shut down
{"payload":"1,3,0,1","instruction_type":"S7"}
