Positioning Universal FJ1500LA
Positioning Universal FJ1500LA is a professional-grade 4G GPS tracker with a set of inputs and outputs. The device features crash detection, driver behavior monitoring, driver identification, driver authentication, message logs, and temperature sensing.
Parameters (69)
Flespi parses telemetry data from your Positioning Universal FJ1500LA into a standardized JSON and lets you send commands to Positioning Universal FJ1500LA via API.
    "device.type.id": "Positioning Universal FJ1500LA",
How to send commands to Positioning Universal FJ1500LA?
can.j1939.spn.data
can.snapshot.data
can.snapshot.number
can.snapshot.sequence
main.power.status
Main power state
obd.pid00
obd.pid20
obd.pid40
obd.pid60
obd.pid80
obd.pidA0
product.id
Product ID
