Positioning Universal FJ1600LW
The FJ1600MW is targeted as an under-dash full featured mobile fleet gateway product ideal for mobile resource management. It features world-wide 4G connectivity, robust input/output capabilities, BLE 5.0, and Dual Vehicle Engine Control Unit (ECU) interfaces. The FJ1600MW also offers users advanced capabilities such as impact/crash detection, driver behavior (rapid acceleration, rapid braking, and harsh cornering), engine hours usage, movement/motion, and maintenance management.
Parameters (69)
Flespi parses telemetry data from your Positioning Universal FJ1600LW into a standardized JSON and lets you send commands to Positioning Universal FJ1600LW via API.
    "device.type.id": "Positioning Universal FJ1600LW",
How to send commands to Positioning Universal FJ1600LW?
can.j1939.spn.data
can.snapshot.data
can.snapshot.number
can.snapshot.sequence
main.power.status
Main power state
obd.pid00
obd.pid20
obd.pid40
obd.pid60
obd.pid80
obd.pidA0
product.id
Product ID
