Positioning Universal FJ2100MW
The FJ2100MW is a professional grade OBD plug-in product with robust vehicle Engine Control Unit (ECU) interface supporting both light-duty and heavy-duty vehicle interfaces.
Parameters (69)
Flespi parses telemetry data from your Positioning Universal FJ2100MW into a standardized JSON and lets you send commands to Positioning Universal FJ2100MW via API.
    "device.type.id": "Positioning Universal FJ2100MW",
How to send commands to Positioning Universal FJ2100MW?
can.j1939.spn.data
can.snapshot.data
can.snapshot.number
can.snapshot.sequence
main.power.status
Main power state
obd.pid00
obd.pid20
obd.pid40
obd.pid60
obd.pid80
obd.pidA0
product.id
Product ID
