Positioning Universal FJ1510LW
The FJ1510LW is professional grade under-dash fleet product with a robust set of input and outputs. The FJ1500 also features advanced capabilities such as impact/crash detection, driver behavior monitoring, driver identification, driver authentication, message logs and temperature-sensing. The unit is designed to be professionally installed.
Parameters (69)
Flespi parses telemetry data from your Positioning Universal FJ1510LW into a standardized JSON and lets you send commands to Positioning Universal FJ1510LW via API.
    "device.type.id": "Positioning Universal FJ1510LW",
How to send commands to Positioning Universal FJ1510LW?
can.j1939.spn.data
can.snapshot.data
can.snapshot.number
can.snapshot.sequence
main.power.status
Main power state
obd.pid00
obd.pid20
obd.pid40
obd.pid60
obd.pid80
obd.pidA0
product.id
Product ID
