can.j1939.spn.data
J1939 custom PGN/SPN report data array
*pgn* - Parameter Group Number
*data* - Raw 4-byte SPN data value
can.snapshot.data
CAN snapshot raw frame array - high-resolution capture of raw CAN bus frames
*delta* - time in ms since the previous captured frame
*id* - CAN frame identifier in HEX
*data* - raw CAN frame payload bytes in HEX
can.snapshot.number
can.snapshot.sequence
main.power.status
Main power state
obd.pid00
obd.pid20
obd.pid40
obd.pid60
obd.pid80
obd.pidA0
product.id
Product ID
