Positioning Universal FJ2050LV
Positioning Universal FJ2050LV is a professional grade 4G OBD plug-and-play GPS tracker. The device features a vehicle Engine Control Unit (ECU) interface supporting both light-duty and heavy-duty vehicles interfaces, comprehensive I/O Configurations. multiple 16G 3-axis accelerometer options for motion sensing, driver behavior & impact detection, OTA device management, and more.
Parameters (69)
Flespi parses telemetry data from your Positioning Universal FJ2050LV into a standardized JSON and lets you send commands to Positioning Universal FJ2050LV via API.
    "device.type.id": "Positioning Universal FJ2050LV",
How to send commands to Positioning Universal FJ2050LV?
can.j1939.spn.data
can.snapshot.data
can.snapshot.number
can.snapshot.sequence
main.power.status
Main power state
obd.pid00
obd.pid20
obd.pid40
obd.pid60
obd.pid80
obd.pidA0
product.id
Product ID
