Positioning Universal FJ2500LS
Positioning Universal FJ2500LS is an enterprise-grade sealed asset monitoring product with an environmentally sealed enclosure. The device features a wide operating range, ultra-low sleep power currents, robust input and output capabilities, a rechargeable 1-year (5200 mAh) battery, CAN interface, Bluetooth radio, dual cellular antennas, and more.
Parameters (69)
Flespi parses telemetry data from your Positioning Universal FJ2500LS into a standardized JSON and lets you send commands to Positioning Universal FJ2500LS via API.
    "device.type.id": "Positioning Universal FJ2500LS",
How to send commands to Positioning Universal FJ2500LS?
can.j1939.spn.data
can.snapshot.data
can.snapshot.number
can.snapshot.sequence
main.power.status
Main power state
obd.pid00
obd.pid20
obd.pid40
obd.pid60
obd.pid80
obd.pidA0
product.id
Product ID
