Positioning Universal FJ970MW
Built for light duty vehicles, the FJ970MW is a high value 4th generation tracking device featuring fully configurable settings, Bluetooth low energy and a robust device management system that is easily scalable to millions of devices. The device provides primary telematics features including advanced driver-behavior and crash detection maximizes safety on the road, while security keeps your sensitive data safe.
Parameters (69)
Flespi parses telemetry data from your Positioning Universal FJ970MW into a standardized JSON and lets you send commands to Positioning Universal FJ970MW via API.
    "device.type.id": "Positioning Universal FJ970MW",
How to send commands to Positioning Universal FJ970MW?
can.j1939.spn.data
can.snapshot.data
can.snapshot.number
can.snapshot.sequence
main.power.status
Main power state
obd.pid00
obd.pid20
obd.pid40
obd.pid60
obd.pid80
obd.pidA0
product.id
Product ID
