Positioning Universal TM94MW
Built for light duty vehicles, the FJ940 is a high value 5th generation tracking device featuring fully configurable settings, Bluetooth low energy and a robust device management system that is easily scalable to millions of devices. While this device provides primary telematics features, it also creates new possibilities with an Edge AI deep learning Neural Decision Processor sensor with Over-The-Air (OTA) updatable models to detect and take action in theft, safety and audible events.
Parameters (69)
Flespi parses telemetry data from your Positioning Universal TM94MW into a standardized JSON and lets you send commands to Positioning Universal TM94MW via API.
    "device.type.id": "Positioning Universal TM94MW",
How to send commands to Positioning Universal TM94MW?
can.j1939.spn.data
can.snapshot.data
can.snapshot.number
can.snapshot.sequence
main.power.status
Main power state
obd.pid00
obd.pid20
obd.pid40
obd.pid60
obd.pid80
obd.pidA0
product.id
Product ID
