You can obtain telematics data from any Eview device in 6 easy steps:
Set up the Eview channel in your flespi.io interface.
Point an Eview device to your flespi account using the device configurator from Eview or by sending an SMS command to the device.
Access Eview device data via API.
2. Set up the Eview channel in flespi.io
The Channel dialogue box will show up. Enter the name for the channel (any text will suffice), select “eview” in the protocol_id drop-down menu, click 'SAVE + OPEN'.
3. Point your Eview device to your flespi channel
You can do it with an SMS command to the device (syntax is provided below). The domain name and port to point the device to are shown in the channel box.
The syntax of the SMS command is as follows:
IP1,<domain name>,<port>
While in the Channel dialogue box, click on the Logs & Messages tab. Inspect log records to confirm that your device has successfully connected to flespi. The presence of messages in the lower half of the screen will confirm that the incoming data is parsed. Please keep in mind that in as Logs section runs in realtime it will reflect any connection attempt. Hint: you can right-click on a message or log to show corresponding raw traffic.
5. Access Eview device data via API
"result": [
"battery.charging.status": false,
"battery.level": 100,
"channel.id": 55549,
"device.id": 4637051,
"device.name": "Eview 206M",
"device.type.id": 1215,
"fall.alarm.status": false,
"gnss.status": false,
"gsm.network.status": false,
"gsm.signal.level": 24,
"ident": "862749050768273",
"peer": "46.114.227.184:20310",
"position.altitude": 233,
"position.direction": 200,
"position.latitude": 48.973751,
"position.longitude": 9.281076,
"position.satellites": 4,
"position.speed": 1,
"position.valid": true,
"protocol.id": 254,
"server.timestamp": 1705321861.422052,
"timestamp": 1705321881
}6. Create a flespi device
This step takes interaction with your device on a qualitatively new level — get access to device telemetry, easily send configuration commands, configure post-processing using plugins, aggregate messages into intervals, and benefit from extended message storage.
What's next?
