Gosafe G6C
Gosafe G6C is a quad-band GSM/GPRS/LTE tracking device perfectly suitable for a variety of applications: fleet management, insurance telematics, dispatch, vehicle location and recovery, and more. The device features multiple input & output, GSM jamming detection, RS232 serial port, geo-fencing, etc.
Parameters (158)
Settings (11)
Gosafe G6C
Flespi parses telemetry data from your Gosafe G6C into a standardized JSON and lets you send commands to Gosafe G6C via API.
    "device.type.id": "Gosafe G6C",
    "protocol.id": "gosafe"
How to send commands to Gosafe G6C?
accident.event
Accident event detected
Alarm mark bitmask
backup.battery.voltage.status
Alarm mark bitmask
call.status
Call status bit
cornering.acceleration
Cornering acceleration
crash.timestamp
Crash timestamp
device.mode
Device working mode code
Additional info ID 0x2A,
Alarm mark bitmask
flash.storage.status
Flash storage status
frequency.counter.din
fuel.weight
Fuel weight
Alarm mark bitmask
gsm.sim.balance
SIM card balance
hardware.fault.code
Hardware fault code
hardware.malfunction.alert
Alarm mark bitmask
Alarm mark bitmask
harsh.turn.event
Harsh turn event detected
Alarm mark bitmask
Alarm mark bitmask
message.content
Message content
Alarm mark bitmask
position.fix.type
Alarm mark bitmask
Alarm mark bitmask
Alarm mark bitmask
Alarm mark bitmask
Alarm mark bitmask
sensor.status
socket.connection.status
Socket connection status
Alarm mark bitmask
Message ID 0x0704
trip.type
Trip type (Private, Business)
turnover.event
Turnover event
Alarm mark bitmask
Alarm mark bitmask
ADC data bitmask
adc_data
adc1: ADC1 Voltage
adc2: ADC2 Voltage
COT data bitmask
cot_data
in0: IN0 frequency/pulse data
in1: IN1 frequency/pulse data
in2: IN2 frequency/pulse data
in3: IN3 frequency/pulse data
mileage: Mileage
engine_hours: Engine hours
DTT data bitmask
dtt_data
io_status: I/O Status
event_status: Event Status
device_status: Device Status
dynamic_report_interval
interval: Report interval
data_format: Data format
report_mode: Report mode
Connectivity Setup
gprs_setup
GPRS Setup.
GPS data bitmask
gps_data
hdop: HDOP
vdop: vdop
course: Azimuth
altitude: Altitude
GSM data bitmask
gsm_data
bs1: First Base Station
bs2: Second Base Station
bs3: Third Base Station
bs4: Fourth Base Station
bs5: Fifth Base Station
bs6: Sixth Base Station
bs7: Seventh Base Station
Heartbeat Interval
heartbeat_interval
stop: Stop
acc_off: ACC is off
static_report_interval
System data bitmask
system_data
fw_version: Firmware version
hw_version: Hardware version
device_name: Device name
