GoSafe GAT-3000w
GoSafe GAT-3000w is a solar-powered GPS asset tracker for dry vans, reefers, containers, and other applications. The device features a 10,000 mAh backup battery to keep working for months, a waterproof IP67 casing, LTE connectivity, highly sensitive GPS, multiple sensors and I/O, a detachable harness, and more.
Parameters (158)
GoSafe GAT-3000w
Flespi parses telemetry data from your GoSafe GAT-3000w into a standardized JSON and lets you send commands to GoSafe GAT-3000w via API.
    "device.type.id": "GoSafe GAT-3000w",
    "protocol.id": "gosafe"
How to send commands to GoSafe GAT-3000w?
accident.event
Accident event detected
Alarm mark bitmask
backup.battery.voltage.status
Alarm mark bitmask
call.status
Call status bit
cornering.acceleration
Cornering acceleration
crash.timestamp
Crash timestamp
device.mode
Device working mode code
Additional info ID 0x2A,
Alarm mark bitmask
flash.storage.status
Flash storage status
frequency.counter.din
fuel.weight
Fuel weight
Alarm mark bitmask
gsm.sim.balance
SIM card balance
hardware.fault.code
Hardware fault code
hardware.malfunction.alert
Alarm mark bitmask
Alarm mark bitmask
harsh.turn.event
Harsh turn event detected
Alarm mark bitmask
Alarm mark bitmask
message.content
Message content
Alarm mark bitmask
position.fix.type
Alarm mark bitmask
Alarm mark bitmask
Alarm mark bitmask
Alarm mark bitmask
Alarm mark bitmask
sensor.status
socket.connection.status
Socket connection status
Alarm mark bitmask
Message ID 0x0704
trip.type
Trip type (Private, Business)
turnover.event
Turnover event
Alarm mark bitmask
Alarm mark bitmask
