Positioning Universal TT600
Positioning Universal TT600 is a solar-powered asset tracker with global LTE Cat M/NB-IoT and 2G fallback. It features multi-constellation GPS, a 6‑axis IMU for motion detection, dynamic tracking (up to 1 GPS fix/min, uploads every 10 min when moving), and IP67 rugged design. The self-sustaining solar cell and large backup battery support long life. Secure boot and TLS/SSL protect data. Easy to install with screws or rivets, it suits fleets needing transparent location, speed, and battery monitoring.
Parameters (89)
Flespi parses telemetry data from your Positioning Universal TT600 into a standardized JSON and lets you send commands to Positioning Universal TT600 via API.
    "device.type.id": "Positioning Universal TT600",
    "protocol.id": "positioning-universal-mqtt"
How to send commands to Positioning Universal TT600?
Property charging
Property bat_current
Property bat_percent
Property bat_volt
Property Conc
can.adblue.temperature
Property Temp
Property 46
Property Lvl
Property dtc_m3,
Property dtc_m7
Property 05
Property 5E,
Property fuelRate
Property 04
Property totEngRunTm
Property 5C
Property 0C
Property 1F
Property 9D
Property MPG
Property 2F
Property 10
Property MIL
can.pto.run.time
Property totRunTmPTOActv
Property totIdleRunTm
Property A6
command.id
Property cmd_id
Property fw_dev
Property dev_model
Property ut
Property drv_id
Property ign
Property enghr,
Property enghrs
Property rpt
Property sq
Property extpower
gsm.cell.type
Property acc_band
Property acc_tech
Property acc_net
Property acc_csq
Property hw_ver
mil.status
Monitored status since DTCs cleared. Includes MIL status and Number of DTCs
Property 01
Property fw_mod
Property modem_ver
Property hacc
Property alt
Property bear
Property lat
Property lon
Property pDOP
Property sats
Property spd
Property type
Property vchg_type
Property vdist
Property trip_vbusDistance
Property id
Property temp,
Property value
solar.panel.current
Solar panel current
Property solarma
Property solarmv
Property ts
trailer.door.status
Trailer door status
Property door
Property trip_movingTime
Property trip_vbusFuel
Property trip_vbusFuelPc
Property trip_idleTime
Property trip_gpsDistance
trip.no.fix.duration
Property trip_gpsBadTime
Property trip_start_lat
Property trip_start_lon
Property trip_start_ts
Property trip_end_lat
Property trip_end_lon
Property trip_end_ts
vehicle.battery.voltage
Vehicle battery voltage
Property vbat
Property gdist
vehicle.odometer
Property dodom
Property state
Property vin,
Property vin_coarse
Property x
Property y
Property z
