Queclink CV5000
CV5000 Series is an AI-powered connected dashcam for commercial fleets with LTE Cat 4 and up to four video channels. It features dual microSD (512GB x2), dual‑band GNSS (L1/L5) supporting GPS/GLONASS/BeiDou/Galileo, and built‑in Wi‑Fi and BLE 5.4 for sensor integration and app control. Advanced ADAS/DMS and BSD enhance safety, with live streaming, event uploads, and SOS calling. Telematics include live tracking, geofencing, speeding, harsh‑driving, crash detection, and mileage. Operates on 8–32V, -20 to +70°C, with IMU, mic/speaker, HDR Sony STARVIS 1080p, and configurable recording.
Parameters (683)
Settings (10)
Queclink CV5000
Flespi parses telemetry data from your Queclink CV5000 into a standardized JSON and lets you send commands to Queclink CV5000 via API.
    "device.type.id": "Queclink CV5000",
How to send commands to Queclink CV5000?
CAN100 Information
can_info
CAN100 module information
serial: Serial Number
sw_ver: Software Version
DSS Event Configuration
dss_event_config
Configure Driver Safety System (DSS) event detection parameters per event (AT+GTDSS command). Each event ID is configured separately: DMS events (1-8), ADAS events (20-23), BSD events (30-31).
event_id: Event ID
report_enable: Report Enable
trigger_speed: Trigger Speed
silent_duration: Silent Duration
sensitivity_level: Sensitivity Level
dms_distract_scope: DMS Distract Scope
Multimedia Event Trigger Configuration
event_trigger_config
channel_index: Channel index
video_event_mask: Video event mask
video_upload_mask: Video upload mask
picture_event_mask: Picture event mask
picture_upload_mask: Picture upload mask
forced_event_audio_mask: Forced event audio mask
event_recording_duration: Event recording duration
Server for Transferring Files
file_transfering
server: Upload mode
Fixed Report
fixed_report
Fixed Report Configuration: periodic position reporting (AT+GTFRI command). Send Interval / Check Interval ratio must not exceed 15.
eri_mask: ERI Mask
igf_interval: IGF Report Interval
corner_report: Corner Report
send_interval: Send Interval
check_interval: Check Interval
Global Configuration
global_configuration
Configure CV5000 global parameters (AT+GTCFG command)
events: Events
led_on: LED On
odometer: Odometer
pwr_mode: Power Saving Mode
agps_mode: AGPS Mode
gsm_report: GSM Report
osi_report: OSI Report
device_name: Device Name
gnss_lost_time: GNSS Lost Time
position_append: Position Append
incoming_control: Incoming Call Control
rto_serial_number: RTO Serial Number
report_composition: Report Composition
Multi Recorder Parameters
recorder_params
channel_1: Channel 1
channel_2: Channel 2
channel_3: Channel 3
channel_4: Channel 4
record_audio: Record audio
recording_beep: Recording beep
rec_time_ign_off: Recording time after ignition off
sub_stream_record: Sub stream record
Request Log
request_log
Upload device diagnostic logs
time_range: Time Range
Volume and TTS
volume
call_volume: Call Volume
ring_volume: Ring Volume
voice_option: Voice Option
tts_alerts_mask: TTS Alerts Mask
ring_alerts_mask: Ring Alerts Mask
multimedia_volume: Multimedia Volume
Stop videostream
stop_videostream
Stop videostream
