Queclink GB100
Queclink GB100 is a battery-mounted insurance GPS tracker with Bluetooth support. The device features a 3-axis accelerometer, integrated GSM and GNSS antennas, driver behavior monitoring, power saving, motion detection, IP65-compliant casing, and more.
Parameters (683)
Settings (15)
Queclink GB100
Flespi parses telemetry data from your Queclink GB100 into a standardized JSON and lets you send commands to Queclink GB100 via API.
    "device.type.id": "Queclink GB100",
How to send commands to Queclink GB100?
Device Parameters
config_gb
agps: AGPS Mode enable
led_mode: LEDs working mode
odometer: Odometer
pwr_mode: Power saving mode
device_name: Device Name
gps_lost_time: GPS lost time
Events
events_gb
igl_event: Send GPS position when virtual ignition on/off
ign_event: Report virtual ignition on/off events
pfa_event: Power off event
pna_event: Power on event
External Power Supply Alarm
ext_power_alarm_without_output
sync: Sync With FRI
debounce: Debounce Time
Fixed Report
fixed_report_gb
mode: Working Mode
corner: Corner Report
time_range: Time Range
check_interval: Check interval
GNSS Assisted Motion
gnss_motion_detection_gb100
GNSS assisted motion detection settings
speed: Speed Mode
enable: Enable Function
move_time: Motion Time
speed_lvl: Speed Threshold
still_time: Motionless Time
gnss_fail_time: GNSS Fix Failure Timeout
GSM Reports
gsm_reports_gb
mode: GSM Reports Mode
reports: Select reports
network_gsm
network_mode: Network Mode
Report Composition
report_gb
alt_enable: Altitude
gsm_enable: GSM tower data
mil_enable: Mileage
dname_enable: Device name
speed_enable: Speed
stime_enable: Send time
course_enable: Course
Tow Alarm
tow_alarm_without_output
Tow alarm configuration
rest_dur: Stillness Timeout
motion_dur: Motion Timeout
tow_enable: Tow Alarm
tow_interval: Tow Interval
virt_ign_accel_gb100
Accelerometer (motion status) virtual ignition settings
rest_timeout: Rest Duration
motion_timeout: Motion Validity
Virtual Ignition Mode
virt_ign_mode_gb100
Virtual ignition working mode
mode: Working Mode
Voltage Virtual Ignition
virt_ign_volt_gb100
Voltage virtual ignition settings
smart: Smart Voltage Adjustment
on_voltage: Ignition ON Voltage
debounce_on: Ignition ON Debounce
debounce_off: Ignition OFF Debounce
voltage_offset: Voltage Offset
